3 Battery Generating System
This topic is closed.
In the past if I had any wire lead sizes that wouldn't quite fit a PCB hole I would either use a tiny drill to enlarge the hole a bit or I've even used a Dremel to grind down the diameter of the leads a bit. Anything to save buying another 2 cent resistorOriginally posted by ehsanco1062 View PostHi ewizard
Thank you ,that's what I thought but I want to be sure that those resistors can
fit into the PCB ,and you make it clear
I have one of these (made back in 70') fitted into small DC motor from a toy. - Mini Keyless Chuck 3/32" Shank For Micro Drill Bits | eBay
It works great for drilling PCB's.
Vtech'Get it all on record now - get the films - get the witnesses -because somewhere down the road of history some bastard will get up and say that this never happened'
General D.Eisenhower
http://www.nvtronics.org
Ya that might work. The big issue with it is a 400 watt, So you might run into problems with it. But you could parallel several if you find a weak point.
The biggest thing I am worried about is the cap dump portion. If your cap is say 10000 uf and you charge it to 48 volt and dump it into a 24 volt battery with that Fet you'll have a 100 nanosecond pulse of 24 volt at 480 amps. Those numbers are off
So you can see that might stress the Fet out a bit, but like I said you can give it a try.
Also make sure to include a good heat sink. Much over 40 deg Centigrade you are going to lower the conduction rapidly. So you wanna keep that little thing cool as possible.
Matt
Hi Matt
Thank you for the explanation although I didn't understand some of it because its above my understanding but I think it dose not worth to try and then blow some thing and then wait untill get the new order which it will be the same as you refer to in previous post I mean
IXFN180N25T-ND It's 155A 250v to be in the save side .
And I ordered also (338-1988-ND) it's 15000mf 100v cap
And this ultra fast diode (30EPH03PBF-ND) It's 300v 30A and the ather parts ar the same as Dave list.
These parts I orderes from Digi-key
Ehsan
Take the wisdom even from the mouths of the insane
Ya thats the safe way to go. You can always lean the system down later once you have all the power mapped out.
The thing you gotta watch is Watts, At least that been my experience. If the watts aren't high and the conduction is not high enough at Higher heat level than usually they don't hold up very well. The other thing you have to watch is the voltage of the transients. If the Bypass diode is not rated high enough the spikes will eat ya up.
Thats what I like about the IXYS miniblocks. They can take beating. They'll still burn up if your not careful but its easier to see whats going on then make the correct adjustment. They have High watt counts and that helps alot.
Matt
Partial Success
Hi all
I'm still working with the original set-up.
I can take 204 watts of power, off the dead battery,...I'm running 3 loads,
an 18volt cordless impact,
" " " " drill,
" " sawsall,
My primaries (good bats) hold and climb, when my switching is working.
If I could keep the switching working properly I'm sure it will run.
I've tried many different mechanical set-up's, but the wires eventually burn out
I have a generator connected to my motor that works off the positive of the dead battery ,and the positive of the # 1 ,good battery , this connects to the positive and negative of the #2 ,good battery.
The switching has to intterupt the flow to the coils(in the charger) at just the right time.
I checked the #'s on the tools (204W), but tried to check what the rad fan was drawing(it was more than 7amps dc,melted the test lead in my hand),
Trying to build some form of brushes or a switch, that's where the answer is.
shylo
I don't use steel for back plates this was my 1st attempt
I tried using an old armature, and a set of brushes as a switch,it worked quite well,the only thing was the more area you cover with the brush,the more drag you create
But if you can make multiple connections at the same time ,in the right sequence, hence the switch
The only way is to reduce the size of the brush(or contact)
shyloLast edited by shylo; 03-17-2014, 12:25 AM.
Questions
Hi shylo,
I am also somewhat confused. I hope you don't mind if I ask some questions to try and understand what you are doing. Also a schematic would be a big help.
Thanks for any clarification you can give.Originally posted by shylo View PostHi all
" " " " drill,
" " sawsall,
My primaries (good bats) hold and climb, when my switching is working. What switching are you talking about? The original circuit only had the batteries and a motor and the load on the dead battery.
I have a generator connected to my motor that works off the positive of the dead battery ,and the positive of the # 1 ,good battery , this connects to the positive and negative of the #2 ,good battery. Are you saying the output of the generator is connected to battery #2?
The switching has to intterupt the flow to the coils(in the charger) at just the right time. Is the charger the generator you have running off the motor that is connected to the positive of the good battery #1 and the positive of the dead battery?
I checked the #'s on the tools (204W), but tried to check what the rad fan was drawing(it was more than 7amps dc,melted the test lead in my hand), Is the rad fan motor the same as the motor that is turning the generator or charger?
shylo
CarrollJust because someone disagrees with you does NOT make them your enemy. We can disagree without attacking someone.
Thanks shylo
Ok now I think I see what you are doing. You are using the coil shorting process that I have seen on some other forums. Are you shorting the coil multiple times at the peak of the voltage curve or only once? I have seen some circuits on this forum or another one for doing that electronically. I'll have to look for it if you are interested in going that way. If I understand the process right this shorting allows you to get a lot more power from the generator without any additional drag on the motor. Is that correct? So then you are able to keep the primary batteries charged while running the 3BGS. Thanks for sharing this with us.
