Now I've got to really think about this last bit, I put together another core, two magnet disks 3" dia, 2 copper disks 2.75" dia all with .25" hole, sandwiched the copper disks with a piece of .125" thick neoprene. 20 turns of 26ga mag wire.
putting a static 9vDC charge on the plates has a very interesting effect on the windings, now the charge is via a wall unit so it's not battery clean. the meter reads 2v AC on the leads if there is a small .001uF capacitor in series. now if I touch the magnets the voltage fluctuates due to my body capacitance. another interesting feature, take the ground lead of the meter and attach to a clean ground, I have a rod for this. leave the positive lead on one of the winding ends, it'll will read ~10vAC, If I touch the magnets the voltage jumps to ~23vAC and climbs to 43VAC.
if I remove the ground lead from the ground and touch it with my finger it'll read ~7VAC.
putting in a diode it'll read .5vDC on the windings.
THis is all with a static 9Vdc charge on the plates in the magnet core transformer.
need to source some highly permeable material to make layered cores with copper plates and see what I get without the impressed magnetic field already in place.
