Eric Dollard
This is a sticky topic.
  • The coils and setup are excellent work the equipment is relative at this point.
    I was hoping you would hit 2075 Kc in the middle of the graph when capacitor is 50%.
    A Spec Analyzer may show what is going on when the air variable capacitor is between 60 and 90 degrees.
    A goal of 2050 to 2100 Kc for the entire sweep would be great goal. I believe it is a successful build. You hit in the ball park.
    great job!
    • "Doesn't matter how many times you kick the coyote in the head, it's still gonna eat chickens". - EPD
      • Originally posted by jpolakow View Post
        Any comments or criticism is welcome!
        Excellent work John. Thanks for the diagrams and info on the primary and phasing.
        • Made a new video utilising the receiving coil. On a related note, some people in the past have objected to the idea/reality that the same system was/is to be used to transmit/receive power and "radio" or intelligence with no fundamental changes to the general arrangement, so three applications are demonstrated simultaneously, or four if the light also be considered as heat. There is NO power supply or amplification on the receiving end, the only power available is that received from the transmitter.
          The motor is geared down, the label on it says 12V 2.2W. The speaker is approx 16" diameter 50W and I believe 8 ohms, the bulb is the 28V type mentioned a few pages back, I forget what #
          Tesla Magnifying Transmitter And Receiver- Light, Intelligence And Motive Power - YouTube
          • Hi All!
            Thanks for the information on how to tune and measure the coils. I am still in the driver construction area but I finished my 6sn7 driver and it works.
            However I have a question. I'm running on 3,2MHz and the mu seems to drop to 5. On 300kHz it is something like 10. My question is was this driver suggested to work with 1MHz and am I correct in saying that 3,2MHz is to much for this tube? I have checked all other possible explanations by using metal film resistors and checking my scope probe that is 100MHz etc. I can find nothing wrong but the tube itself. Please someone with experience with RF and tubes give me a clue! Thanks!
            • orgonaut314, that looks like a really good assembly for tube experimentation. Scribble the circuit down so we can take a look.
              • Originally posted by madhatter View Post
                Thanks, what was used as the PS (power supply) for the TCS 12?
                A dynamotor (dc motor generator) power supply was used, that came with the TCS. It has two dynamotors, one that puts out ~400VDC, and one that puts out ~220 VDC.
                The schematic is below:
                You can see the dynamotor PS next to the Heathkit RF oscillator in this pic:
                Please help support my indiegogo campaign: Cosmic Induction Generator
                • Hi Sputins,
                  Thanks for the comments.
                  Yes you have that right about the coil phasing. The primary direction of winding is arbitrary, but the secondaries MUST be wound in opposite directions. Then the primary connections are adjusted to the proper phasing. Final determination is made by checking with the fluorescent bulb to verify the coils are out of phase.
                  I am indeed driving the secondaries at quarter wavelength. Why did you think I was driving them at full wavelength?
                  • Originally posted by Geometric_Algebra View Post
                    Basically Eric's schema but I coupled it out to avoid the dc but without the out coupling cap the mu also dropped to 5 at 3.2MHz.
                    My input is 3,5V from the frequency generator and it has 4Volt dc at the cathode. The anode has 110V dc.
                    • Originally posted by orgonaut314 View Post
                      Per your schematic the tube is non-functioning. in other words there is no signal on the grid and the cathode R is very small, making for large currents to drain thru it from the plate. What's the goal? I could work up a schematic with values later tonight. it's a simple amp circuit, SE. (single ended)
                      • Thanks Jon, I'll give all the data a look over in the next couple days and see what I can find. I'm trying to locate an internal schematic on the receiver, interesting to see what kind of isolation is occurring between it and PS.
                          Hi its a grounded grid. See this Eric drawing:
                          But the reason why my mu is low might be because the probe from my scope seems to be broken at high frequencies. Have to buy a better one.
                          • Receiver Schematic
                            Hi Madhatter,
                            Here you go:
                            • Here's a couple better ones:
                                thanks hadn't seen this one, it's a grounded grid amp..
                                Grounded Grid Amplifiers
