Eric Dollard
This is a sticky topic.
  • Originally posted by orgonaut314 View Post
    Don't know as the secondary coil should have an electrical and magnetic wave that is max on top. With these iron cores you get a lot of magnetic coupling but little electrical coupling? Not the Tesla wave that Dollard demonstrates with his analog networks. Or do you meen something else than an iron core?
    Somewhere in this wonderful document is a section on the parametric transformer. Thank you Arrend for providing this document, it helped me immensely.
    As you will see, you can use two "C" cores arranged in a special way to provide a small common but orthogonal flux path. In other words, the magnetic field of the primary and secondary are normal to each other. The primary acts to vary the reluctance of this common area. There is NO mutual magnetic inductance! Because of this, the secondary is free to oscillate just like a tesla coil.
    You can actually pump this with DC pulses and get extremely clean sine waves out of the secondary! You can use this to create harmonics as well!
    If you ground one end of the secondary and attach a top capacitive load then you still have a quarter wave machine with the voltage anti-node on the top load just like a Tesla Coil.
    Find the secondary quarter wave resonant frequency (F) and pump the primary with (2F)
    Pure magic!
    • Spiral TMT test - YouTube
      • Originally posted by Sputins View Post
        Cool stuff, I like those vintage style bulbs. Quality/lighting looked fine to me. It takes you 8 hours to upload because it seems to be 1080p so the file is huge. You can probably change it to 720p in your camera settings, that will cut it down by nearly half. But unfortunately that will only apply to new recordings, everything else you've done so far will still take ages to upload.
        • George "Friedrich" Handel
          Thank you for your support!
          • Electromagnetic Induction and its Propagation
            New paper by Eric P. Dollard:
            Electromagnetic Induction and Its Propagation2014 Energy Science & Technology Conference presentation called The Extraluminal Transmission Systems of Tesla and Alexanderson: Electromagnetic Induction and Its Propagation (pdf)
            New page on ericpdollard.com where a collection of his papers will be available as free downloads: Free Papers | Eric P. Dollard – Official Homepage
            • Thanks Eric! The transmission line part gets clearer to me. Beautiful document. Now the aether part and the Faraday tubes. I have seen these pictures from the aether particle from the atom and from the human body and they all look the same.
              • I rarely have visitors in the lab so I took the opportunity to do a two person experiment earlier. Connections as shown.
                • Eric Dollard
                  Very impressive ! What kind of powersupply do you use for this setup? Can you post a schematic ?
                  • Cred
                    How about using the receiver coil (or CIG) with certain bulbs and experimental subjects in between?
                    Credit given
                    • Block Diagram
                      • Eric Dollard
                        Thank you very much for the time taken to write this comprehensive answer. Your block diagram is most helpful to get an overview for the Tesla transformer. I try hard to get a comprehensive knowledge of this technology, but when reading trough the forums as an amateur I am not able to judge what is important, less important and useless. So to get an overview when reading through the forums I have to condense all the useable knowledge until I can envision a starting point to build a specific transformer setup. So I have to envision by myself a specific setup, design it and build it. When I have seen your video on youtube, I thought that could be the set up I want to start to replicate.
                        There is still the question, what is the engineering goal, what can you expect and achieve with this set up?
                        Thank you very much for your time !
                        • whats pi-network? is pi network, like 3.17?
                          • Originally posted by ldrancer View Post
                            A Pi network is a capacitor and inductor arrangement that looks like π, or the character Pi. It is an impedance matching network to match a source to a load impedance.
                            • Thanks! Hehe I like the diagrams, although I think the experimental subject will have question marks floating around his head wherever he stands! It will be even better with your higher power setup. This is the second time I've done it, I usually stand in the middle myself to spare the visitors from plasma burns and what not. We also used 8x 1.5V grain of rice/wheat bulbs in series which looked more impressive/brighter than the big bulb, but my friend was nervous so the moment he started to feel a bit of heat he let go of the thin wires, so that only lasted a few seconds. I doubt he was getting plasma burns after the current had passed through me, that may have been caused by the bulb heating up as normal, but I had not mentioned what kind of effects I usually feel to see if he would comment on anything. But as you know thin wires are not usually the parts you want to hold on to.
                              This was the first attempt at the same thing a couple of years ago, using spark gaps back in the day.
                              A Bulb In Hand(s) - YouTube
                              A receiver works with a bulb and one person in between, so I expect it should work just the same with more people. The only question is the amount of power. Working a speaker on the receiving end is certainly possible.
                              It should be very good to see these things with a bit more power used!
                              • This is an updated experiment with the slightly higher power amplifier compared to last time, and with the bigger capacitance terminal/tuned extra coil. Last time a 1.5V grain of rice bulb was barely lit, this time it popped within seconds.
                                Basic setup is somewhat similar as shown in Colorado Springs Notes page 360, the difference being that my extra coil is connected to the top of the secondary rather than a ground plate.
                                Actual connections
                                28V bulb, transmitter not at full power
                                28V bulb, all the lab lights off
                                Within 3 minutes the 28V bulb had blown
                                240V 15W bulb
                                240V 15W bulb, all the lab lights off
