Eric Dollard
This is a sticky topic.
  • ERIC DOLLARD LIVE CALL TOMORROW NOON PACIFIC TIME
    Call in for the latest updates and ask Eric Dollard questions live - Saturday, February 8th, NOON Pacific Time Zone. Call +1 857-232-0155 and enter the code 582590 to access the call.
    Come ask Eric Dollard questions live or just listen in!
    In the meantime, consider donating to EPD Laboratories, Inc to support the work of Eric Dollard. Information on donating by mail or by PayPal are on http://ericpdollard.com
    • ERIC DOLLARD LIVE - starts in 10 minutes
      • Note to Eric for feedback:
        • For the Record:
          Crystal Radio Set Initiative - CSI:
          https://kupdf.net/queue/crystal-radio-initiative_5af89140e2b6f5131fd54e23_pdf
          Confirmation of a particular condition with this device where I had a 'run-in' with Eric Dollard.
          He called me a 'zealot' as he was suggesting that my interpretation of conditions was wrong and that he was right.
          I had already proven by build that his Extra Coil was wrong (too fine a wire and way too many turns) and the one that I had made was working and was able to hear a re-radiated signal from the Extra Coil some 20" distant from it where his was dead.
          In the back of my mind during this entire experimentation build that I did not know at what frequency Tesla was actually using and this always bothered me and I guessed at about 94.7 Khz with a possible Pi/2 connection to 148.75 Khz (my 'multiply').
          This is my extract from that conversation and is available on Page 220 of 302 of the CSI PDF above:
          Do the quick math here and you get 60.267 * Pi/2 = 94.6672kHz * Pi/2 = 148.703Khz
          Both wire lenghts for the secondary and the Extra Coilare for the same frequency of 94.6675kHz.
          In this I see a 'one-wire' connection to the Extra Coil in free space that would allow it to resonate at something other than the Transverse Electro Magnetic TEM frequency achieved by a simple transformer association.
          Tesla never mentions this in his Notes and I suspect he has done so to retain ownership of the theory which he simply does not approach from any direction whatsoever.
          I had come in late with this CSI build and had already done considerable home work before I attempted the build and had fully read the 'Colorado Springs Notes' several times and had made up my own calculated coil sizes which didn't necessarily match those of Eric and this was also prominent in the number of turns in the secondary where we also disagreed.
          I made up a small chart to show where he was working and where I was and called it a 'divide' or 'multiply' situation - see attached.
          This shows where Eric was working in the 'divide' part of the waveform and where I was working in the 'multiply' part and all this meant and showed was that Tesla was working also in the 'multiply' area and NOT the divide.
          I have reread postings here and am somewhat ashamed by my attitude as it was not real nice and I came over a little strong and my unreserved apologies apply.
          However, I remain convinced that I was right and have had confirmation of that theory from Bruce L Cathie and his Book 'The Energy Grid - Harmonic 695'.
          How sad that all of the initial builders slowly disappeared and can only put this down to an experimental research type environment where all of the facts are not presented clearly or are simply not known and it just takes time to nut all of these particular problems out.
          Well, lo and behold, here I am reading Bruce L Cathie's Book 'Harmonic 695' and what do I see:
          "He discovered that a rate of 150,000 oscillations per second which produced electrical pulsations with a wavelength of 2,000 meters was necessary to produce the effects he required in the transmission of usable power through the earth."
          AND
          "The exact number of cycles to obtain 1.08 minute wavelength would be 149,892.18 per second. This would tune the transmitter in harmony with the world grid system".
          AND
          The experimental value was therefore very close to 1.08 minutes of arc, or one twenty thousandth of the circumference of the earth. 21600 minutes divided by 1.08".
          2,000 meters to a minute of arc = 1.0792237 Page 107.
          Tesla had to ensure that he was radiating a signal in free air that also contained energy and this had to be something other than the TEM component which is a metal mass component.
          So the addition of the 'Extra Coil' after the secondary allowed something 'out of the box' to be generated and in such was the LMD component at C*Pi/2 speed and using no conductors.
          Tesla was in tune with all of this but did not make it a part of his notes and was probably his secret in a bid to retain ownership.
          So, just how close was I and correct in the mind games and now wanting to get back to that experiment.
          I feel that Bruce Cathie had also deduced as I had, that Tesla had designed to use the LMD component of the 'Extra Coil' on the multiply side to achieve an earth resonace at the 149Khz.
          Do I dare present this to the Dollard Forum?
          The implications of this simple review is kind of mind boggling as it is the difference between a working and a non-working Tesla Magnifying Transmitter (TMT) or one that is damn difficult to tune and one that isn't.
          Doing my best to get back into the Lab for brief periods to complete all of my Projects as the CSI is but one of about 5 and all having OU prospects.
          Aaron - Is it possible to get Eric back at the Forum where we have many questions to be addressed as it IS his Forum - Thanks.
          Good to see the Linear Amp coming along and looking forward to further progress reports.
          A Live Call with Eric is simply out of the question here.
          Smokey
          • Tesla Colorado Springs:
            Always something here that bothers me and I go back to the CS Notes to try to fathom out.
            I had made an error in an earlier calculation and in review find the result was appropriate as it again, confirmed both mine and Bruce Cathie's theory.
            Page 349 and we are dealing with frequency n = 93,110 and p = 585,000 which is final full wave frequency but how do you get to that level?
            Simple:
            93,110 * Pi/2 = 146,257 * 4 = 585,000
            Page 80 top of page:
            p = 2Pi * n
            OR
            p = Pi/2 * n * 4
            Same thing, however, I do it the P1/2 way to show each step in the process.
            There you have it, you simply have to search for your answer.
            In all of this we are transmitting at the Earth Resonance Frequency (ERF) of about 148 Khz via the Extra Coil.
            I have designed a 10' x 6" pvc tube ground aerial after Rogers that is in four sections that are able to be fully rotated from outside the tube at ground level or the four sections can be aligned in a Polar manner or straight line.
            An attempt to verify some of the features of ground aerials or as energy collectors.
            Quartz rock is used as the filling around the pvc tube and this is analogous to a massive crystal radio crystal with its inherent radiation properties.
            Tesla and his Coherer is still vivid in my mind as I can see earthly currents being able to agitate this quartz mass as are generated by distant thunderstorms as in Tesla's 500 miles 805 kms.
            That, by the way is from Sydney to Brisbane or San Francisco to San Diego.
            My problem is that we are still here on our property but may still go ahead with this idea as it may just beat a strung wire and nobody appears to want to experiment with these old and hidden radical ideas that work.
            Eric's Electrical Experimenter.
            Smokey
            • Aaron,
              In the older format you had activated an Email notification that was sent to Forum members when a new Post was received.
              Is that possible to be implemented here?
              All I am doing is to get some of those people back who were involved with the original Crystal Set Initiative.
              They are missing out on basic and valuable information.
              Smokey
              • Originally posted by David G Dawson View Post
                Aaron,
                Smokey
                To answer your other question - posts here by Eric are possible when he is with someone who is able to login and make the posts for him with him sitting right next to him.
                I'll see what I can do.
                Sounds like you're describing the option for people to subscribe to a thread? That still exists. At the top right corner of any thread on any page, there is a button +Subscribe, I think that is all they have to do after they're logged on.
                Let me know.
                • Eric, here's the latest update - I think there is supposed to be something next to the hv potential transformer on the rectifier panel - some HV terminal strip that is supposed to be elevated?
                  Click image for larger version  Name:	20200227_153956.jpg Views:	0 Size:	826.0 KB ID:	496752
                  Click image for larger version  Name:	20200227_171947.jpg Views:	0 Size:	1.14 MB ID:	496753
                  Click image for larger version  Name:	20200227_171922.jpg Views:	0 Size:	1.03 MB ID:	496754
                  Click image for larger version  Name:	20200227_171947.jpg Views:	0 Size:	1.14 MB ID:	496755
                  Click image for larger version  Name:	20200227_171955.jpg Views:	0 Size:	1.18 MB ID:	496756
                  Click image for larger version  Name:	20200227_174935.jpg Views:	0 Size:	1.24 MB ID:	496757
                  Click image for larger version  Name:	20200227_175006.jpg Views:	0 Size:	1.16 MB ID:	496758
                  Eric, for the video, click in the middle of the image below and it will open up bigger. Then click the play button in the middle of it and it will start playing.
                  • Sincerely,
                      Thanks Aaron
                      • Nikola Tesla:
                        Факултет техничких наука у Чачку је основан 1975. године. Образовно-наставни процес је у потпуности усклађен са европским системом образовања, што је потврђено акредитацијом установе и студијских програма основних, интегрисаних, мастер и докторских академских студија.
                        Very clear picture of the Lab components - see attached.
                        Note the so called spark gap C1 - C2 which isn't - it is a PLASMA GAP and this is the same discovery made in my 'Impulse Discharge' device and why a rope is used to adjust the gap balls to a maximum efficiency and is the same as adjusting a coil or capacitor in a transmitter for minimum plate current.
                        When you do this adjusting you would be looking at a power meter telling you how many amps you were consuming at the input and at the peak, the meter would drop to a minimum with just a plasma across the balls - no spark.
                        The system begins to sing when that plate current is reduced to minimum.
                        TEM transmit - direct connection via variable L & C.
                        LMD transmit - indirect connection via a variable Plasma Gap.
                        I believe our Crystal Set Initiative (CSI) is a little back to front at the Extra Coil as we used two large copper rings between the Secondary and the Extra and think it better to use two adjustable balls after the extra as in the attached schematic.
                        However, this setup was probably used more as a test bed to determine tuning characteristics and efficiency.
                        Will get to this when I can get back to the bench.
                        Smokey
                        • Aaron,
                          It is the 'subscribed' icon at top right and just before the Posts begin that needs to be highlighted.
                          When you sign in, this becomes active.
                          Thanks.
                          Smokey
                            Aaron,
                            Thanks.
                            Smokey
                            What do you mean?
                            • LIVE CALL WITH ERIC DOLLARD, APRIL 4, SATURDAY, 1200PM PACIFIC TIME
                              We're guessing a lot of people will be available to call in due to the stay at home recommendation or orders so call in and ask some questions! There is some interesting astrological elements in play that Eric would like to discuss along with his other work so not only interesting but might be a pretty unique talk.
                              To get on the call, simple call in with a phone, skype voice or any other app that can call land lines: +1-857-232-0155 and enter the pin code: 582590
                              • New thread started by Eric Dollard: http://www.energeticforum.com/forum/...ic-forecasting
