Coil tuning
Hi dR-Green:
Thank you for the response. I will eventually do the suggested tests but first I want to find out what is the best wire spacing on the secondary for max frequency response. Second, I will build a new extra coil using #13 AWG in lieu of #25 AWG. The problem with holding the can and the meter is that it do influence the readings, but I have to have short leads from meter to ground and between meter and can in order to minimize their contribution to capacity. I noticed even my body's proximity to the test set up influences the readings, so normally I have to step back after frequency adjustment to see that the meter stays at that maximum. One would need a real laboratory setup to do these tests properly. Who would have thought that Eric's simple CRI sketch would require so much effort to be successful.
If I use a shortened version of the extra coil, i.e. connect at the 49.5 m point then I do get resonance at 1,186 Kc (pretty close to my target 1,188 Kc) with the condenser rings 64 mm apart. Are you suggesting to tune the secondary coil with a full length extra coil for 1,188 Kc by adjusting the rings' spacing?
P.S. Comments from Eric or any of the other builders also welcome, except I know currently we lost Eric to the wilderness.
Hi dR-Green:
Just takes an hour or two per test to tune the thing when particular frequencies are being aimed for that's all
Or at least as far as these particular geometries go. If not then I dunno
I'll also be rewinding the secondary with thicker wire after I've tested everything with the existing secondary.
, the angle of hysteresis, and Saturation gives rise to a modulation factor,
, the depth of modulation. Hence the sine wave of Inductance variation is expressed by the term,
, is the time rate of its variation,
, has become a tensor magnitude, or a Tensor Frequency. The angular rate of variation is thus symbolically expressed by,
