The voltage on the generator coil is not what it can flow constantly and may be misunderstood. I like to think of it as the potential building up. It is also tied back into the negative leg of the circuit which increases it somewhat. I will do some load tests on the generator side of things when I get around to it. It does have the potential to charge on the back end or pop forward to the primary I believe when done correctly.
As far as a wider diameter rotor goes I cant speak from experience. Maybe I will have to build one of those too.
No other mechanical difficulties so far with the new strapping, but I still get scared. Just to note. The video of it running on 36v 1amp was around 750rpm. With the tweaks and extra power windings it is over 1000rpm for 5/600ma. Amp draw @ startup is over 7 amps, and it rockets back to under an amp as it speeds up.
