I have my first Bedini SG up and running for a few days. I tryed to tune the system for the flashing bulb in the trigger wire. I used a 50mA and a 100 mA bulb as single, in series and parallel.
I only get a glimming of the bulb if poti is closed or nearly closed. Any further and light goes off, rotor stalls. In every combination of bulbs.
Then i tryed different base resistors. Difference is only the brightness of the bulb. Different coil gaps i tested, too.
So i'm quite stuck right now
Any ideas what i can try? I'm new to this Bedini experiments and maybe the problem is in my little understanding of the matter (or antimatter)...
Thank you!
Thank you!
.I will inform you later . Yes mine is a solid state. Just normal SSG and added two resistors to become SS.
