Hi patrick, thanks for the reply and info.
So what capacitor dump circuit are you using, thanks.
Also, the way your charging the 6 volt input battery, integrating it with another 6 volt in series with it in your ssg video is a good idea, since the motor will not be bogged down as much, if at all with that setup. Did not think of ever doing that.
Clever method, wonder how that will work with solid state.
It appears that your setup is self sustaining when swapping the series input batteries back and forth, am I observing this correctly.
peace love light
tyson
edit: or are you using a triac for the cap dump.
peace love light
tyson
It is good idea to turn the light off so no one can see it. Similar principle here. Circuit cannot "see" this operation. In other words, you can collect the charge (in capacitor) and pulse back to the primary battery but this has to be done when the primary is disconnected. It has to be timed well and I would suggest using converted negative (bridge rectifier on the output not just a diode). Mysterious S1 switch on many drawing by John Bedini is not for powering system on and off but to be closed for very short time in the right moment. When the power is disconnected from the input collected charge can be pulsed over the primary source without causing too much confusion among ions. Same idea can be used with window motor. Collected charge can be used to pulse secondary or primary battery. Bipolar switch can be used for SSG and window motor.
Hello my name is Allen - i know this isnt the right thread to introduce myself so forgive me...
controller and motor for the brushless with the kind of horsepower i need are very expensive...
my ideal is to produce a generator that would individually charge the individual 3.2 volt cells. using i what im thinking of multiple capacitor storage then dumping their charge to the cells individually like a pulse... is this possible?
