yeah ren good advice for tjnlsn255
Depend if you rotor is South or North pole, use a compass to verify magnets poles sides. (If you don't have a compass you can take a magnet attached over a cork and putting on the water with vertical poles orientation, the magnet self aligned on Earth poles, then South magnet pole is attracted by Earth North pole (but remember earth north pole is magnetically south pole).
Mark the magnet and test the rotor magnets with him.
If your rotor is correct (normally north pole faces out), you can take a 220 ohm resistor and connect to positive to Base transistor, and your transistor must to activate the coil and rotor must be repelled. If coil don't turn on must check the transistor....
good luck.
good luck.
