Photos
No need to apologize, we're all trying to figure out how this stuff works on one level or another. BTW, a good website to look at (even as refresher material) is All About Circuits : Free Electric Circuits Textbooks.
) I posted what I thought about how the thing works; now I think I have a better handle on it and will post a better explanation. I just need a free block of time to draw the pictures.
). In the past year I've built a few more of these Bedini contraptions trying to see what they can do and I think I finally understand after having beat my head against quite a few walls.
At any rate, I thought I'd post pictures of my 4PMP that I promised to post over a year ago.
But at least now I have a pretty good idea why that is (NB to Peter L.: I checked the battery running that machine by doing a frame-by-frame and looked up the numbers at the manufacturer and it's definitely a 12V battery on the front end).
At any rate, this machine probably has the best torque out of any that I ever have built--it only take a tiny push to get it going, and it fights back when I try to slow it down with my fingers.
It's easy to see how you could develop even more torque with a slight variation on this design.
Thank you so much for sharing it with us!
Also, I've drawn flows coming from the positive this time around, but it all still works even if you draw the flows coming from the negative. So, here we go:
With a bit of mass on the rotor you can build up momentum as well. What can be done with that is left as an exercise for the reader.
What resonance (and RPM) the rotor settles into ends up being a function of the strength of the magnets, the quickness with which the iron core lets go of its magnetism, the coil geometry, the friction in the bearings, and probably a few other things I'm forgetting.
John, Peter and Aaron are quite correct when they say that understanding this machine is the key to understanding what this energy is and how to use it. Good luck in your studies.
) The magnets are only there in mockup form, I haven't epoxied them in yet hence the tape.
however on my trifilar SSG I normally get a 36-48v spike on the primary coil before the flyback current kicks in. But when I hooked the negative side of the circuit to earth the spike is cut down by a third. Don't know if that means it inhibits the spike or whether it allows the circuit to make use of it.
