Parallel Ground Test Results
Hello Everyone,
Last week I ran a test with the SSG's charging battery ground connected to the power ground and noticed an improved charging effect. I ran some additional tests on the 7Ah battery and ~12.1v power supply and the results were encouraging.
Tests 1-8 were run with no rest period after charging. Tests 9-11
had a one hour rest after charging. Load is discharged through 50 ohm resistor down to 12.4v.
Observations :
So what's happening here?
I would love to hear your thoughts and especially those of you with scopes try this test on your SG machines and see what you get.
Warm regards,
Mike
Hello Everyone,
HTML Code:
--------- Charging ------- ------ Loading -------- Cycle Mins W In Mins Wout COP 1 60 2.93 34 1.84 0.63 2 61 3.03 36 1.94 0.64 3 95 4.67 59 3.18 0.68 4 89 4.34 57 3.08 0.71 5 124 6.1 75 4.06 0.67 6 62 3.05 38 2.05 0.67 7 90 4.43 64 3.45 0.78 8 120 5.86 90 4.85 0.83 9 60 2.95 30 1.59 0.54 10 85 4.29 85 4.52 1.05 11 122 6 84 4.46 0.74 Notes : Average COP 0.72
- Wheel speed was 17% slower and slower to rise
- Tuning the pot was very steady with little current bounce
- Using the LED strobe, there are two pulses per magnet (vs. three normally)
- Pulse on time appears to be delayed somewhat, exactly like the video Lee posted with an inductor in the trigger circuit.
- Output Current increased to 140mA vs. 80mA when connected normally
- Test #10 discharged to 12.38v
I would love to hear your thoughts and especially those of you with scopes try this test on your SG machines and see what you get.Warm regards,
Mike
. Also if you can suggest where to place my meter so i can get a proper reading amp draw too in helping me finding where the sweet spot is. Right i now i being drawing 2.1 amp from primary battery,and i conneted the meter to read amp at the top of the primary coil side.
Man and Magnetisim go great together. I want to continue perfecting the ssg i and also tell people about so it can spread, that no government can stop the public from learning the truth. Give power back to the people
