Bedini Tesla Switch Solar Amplifier
  • #16
    It's on internet since many years
    Good morning guys,
    lost in the sea of free energy devices, you forgot that major invention from John, that he is going to manufacture now: his solid state battery pulser, that he names now Tesla Solar Switch.
    I have always been surprised that nobody ever tried to replicate it, it's the most simple of devices.
    Basic logic chip, transistors and capacitors ... exactly as you saw in the video by John that has now removed prior to start selling the device.
    Abstract: Technical Field:
    (0001) The invention relates generally to a battery pulse charger using a solid-state device and method wherein the current going to the battery is not constant. The signal or current is momentarily switch-interrupted as it flows through either the first channel, the charge phase, or the second channel, the discharge phase. This two-phase cycle alternates the signal in the two channels thereby allowing a potential charge in a capacitor to disconnect from its power source an instant before the capacitor discharges its stored potential energy into a battery for receiving the capacitor's stored energy. The capacitor then disconnects from the battery and re-connects to the power source upon completion of the discharge phase, thereby completing charge-discharge cycle. The battery pulse charger can also drive devices, such as a motor and a heating element, with pulses.
    full patent here: Zero Point Energy - John Bedini Solid State Generator - MDG 2007
    I wish I was an expert in electronic, because I would have free electricity since a long time, but for my private use, because it's patented
    Is it a US only patent, or worldwide cover ?!
    John Bedini is the greatest electrical genius of our time
    • #17
      Originally posted by vrand View Post
      Some famous OU researchers have mentioned OU in their patents, such as Dr. Puharich and his HHO electrolysis invention and Stan Meyers with his water fuel designs. They just explain that is comes from the environment and is not a closed loop system. Tom Beardon in his MEG patent explains it as re-gaging with the virtual particle flux.
      Dr. Randall Mills and his Blacklight Power Co. claim OU in his patents using his own theories to explain where the extra energy comes from. They received $10's of millions of funding from investors to build power plants.
      John Bedini is world famous for his free energy research work and to not mention OU in his patents is strange. Why would his products exhibit OU if his patents don't mention any possibility of it? Why would investors put money in another "battery charger" company? What is so special about his product compared to the 1000's of other chargers on the market?
      Looking forward to hearing more of Bedini's latest product
      • #18
        Yeah thats Funny..
        The real problem is they invalidate their own idiom. Show them an atom and have them explain why does it run perpetually. If as they say there is no such thing as perpetual motion why do we exist? We ARE in perpetual motion 24/7. We are in a perpetual motion changing from one state to the next. Nothing they can say or do will change that.
        • #19
          Reading the Tesla Switch thread and found some comments from John Bedini on the Tesla Switch Solar Charger:
          OU COP 2.79
          #1508 (permalink)
          01-07-2010, 09:46 PM
          John_Bedini
          Senior Member Join Date: Apr 2007
          Tesla Switch
          Bit's,
          I cant say much as this is a company product, but when it finally dawns on what you just saw. you will know to keep working and you will get it. I do hope the best for the world.
          But I will do everything one can do to get it out. its plain and simple no heat in the batteries at all. It's a Modified Tesla Switch Solar Charger, but can be used on the motors also.
          53 watt in 148 out. here is the link. I won't answer the question you posted, but you guys are very close.
          JB
          YouTube - MVI_2378.AVI
          Theory of Operation:
          #1558 (permalink)
          01-10-2010, 11:24 AM
          John_Bedini
          Tesla Switch
          Ok,
          I'm going back all over what we discussed here, I will start at ground zero if I must do that. It should be quite easy to make the simple circuits work.
          Aaron is correct that what Peter and I discussed has been ignored. I also found that what Bill and Ray handed me as a diagram does not work, something is missing from the switch. Where did I get that wave, across the switching transistors in the four battery Tesla switch.
          "Ronald Brandt did not invent the switch as he just was trying to figure out what the circuit was that was powering his electric car and why it kept blowing up"
          The key factor may be the driver transformers!!!!!!!!! in the original circuit.
          Baldinelli is the guy Aaron is talking about, this is the key to the success of the system. In the statements by Gabriel Kron, it is said what to change, Leroy pointed this out in a early post here. The currents can be very confusing as they take place in semiconductors.
          Kron calls them
          'lamellar' currents, A network with the simultaneous presence of both closed and open paths. And, noting a type of armor composed of small plates or lames laced together. Can be Interpreted as, small branch currents combining to form one big current, any semiconductor works this way, even different types of rocks.
          “When only positive and negative real numbers exist, it is customary to replace a positive resistance by an inductance and a negative resistance by a capacitor
          This is a sneaky statement but correct.
          Looking at this statement, if collecting negative energy we use the capacitor, example, SG circuit.
          The battery acts just like a capacitor, resistor, inductor. what is in the SG circuit that uses the positive, the coil. The semiconductor runs on 'lamellar' currents, how else could it move electrons, but through holes, which are branches or small pipes.[/SIZE]
          John B
          There are 3 power versions of the Tesla Switch Solar charger:
          12/24VDC 10A Solar Amplifier
          12/24VDC 20A Solar Amplifier
          12/24VDC 30A Solar Amplifier
          With a COP of 2.79, what would be the Power In vs Power Out for these units?
          Regards, Mike R.
          • #20
            I bought the basic 10A Bedini Solar Switch, and hope to loop it on a battery bank on my electric bicycle
            May be it's possible to kind of self loop if we use a converter before the switch:
            battery to motor
            + battery to converter (24V to 240V) + transformer (240 to 24V) to switch
            Off course there will be lots of loss in the converter + transformer, but it might work. 2 months before testing, waiting for post mail
            If not I will have to set of batteries ans swap them on a regular basis, or with the help of voltage controler ... don't know yet
            I won't comment on this thread until I have something constructive to say, it's a place for replication and experiment, not critics. Please forgive my excessive comments (and no need to respond to this post .
            Thanks and good luck.
            • #21
              show me ONE thing in the universe that's still
              • #22
                OU COP 2.79
                Regards, Mike R.
                More of the OU stuff on the PES page
                Tesla Switch Solar Charger to debut at Bedini conference
                Charger gets here soon will confirm HERE, lets not tell people who dont understand OU that's it OU YET, or they will say "perpetual motion device", that will hurt Rick, John and many others, they dont believe OU yet, we need to be conservative . OU must come into validation by being SELF EVIDENT, by particular disclosure. Have some ideas ill share soon.
                John has done well to show us HERE, lets make sure we dont make that a bad decision for him.
                • #23
                  Hi
                  Can anyone extend what Bedini was trying to convey with these statements?
                  I am curious! Bedini is looking for these special currents, which as he says take place in semiconductors! This reminds me of EFTV8 which Daniel Sheenan was talking about extracting energy from a simple P-N junction, or even I remember Dr Stiffler talking about the same thing. Talking about the fact that the excess energy comes from the diode, namely the p-n junction.
                  Now, i wonder if the depletion area, causes the vacuum pour in energy?
                  I even remember how gotoluc managed to amplify the simple spark in the sparkplug by adding some diodes parallel to the secondary of the ignition coil?!
                  I only wonder, why? Why haven't we been studying the simple diode as an energy extraction device?
                  I think that most of us know and have observed here that we can light up an led which is a type of diode, by changing potential on one of its terminals, with the other terminal floating. Just find a function generator and hook one of an LED's terminals to it, it will light up dimly, but it will, without drawing any external current!! meaning that it generates its own current, coming from the environment. Dr Sheenan believes it comes from the heat in the environment, others say it comes from the vacuum. All of us working with pulsing semiconductors have observed the "cooling effect" these devices have.
                  Some other people such ad Dr Jan Pajak say: Dr Eng. Jan Pajak - autobiographical note (in English)
                  Therefore I do research on such still unknown phenomena as "technical telekinesis" (means the "reversal of friction"), as telepathy, as gravity, as thermal energy of electrons, etc.
                  The reversal of friction (technical telekinesis) is converting heat into motion, which is what happens according to Dr Sheenan in a P-N Junction.
                  I think that the simple devices that we call diodes, should be taken seriously.
                  We should design many different experiments with diodes. Pulsing them with one terminal and high voltages, and extracting energy from them.
                  Hope to see more "understanding" about the diode. I also remember Bedini talking about the LATTICE structure of the silicon, which can act as a pump for the Aether. A P-N junction is two types of Silicions, that meet each-other. Male and Female, and the energy of the vacuum is captured from the Bloch wall which where the opposites meet.
                  Elias
                  http://blog.hexaheart.org
                  • #24
                    The key factor may be the driver transformers!!!!!!!!! in the original circuit.....The currents can be very confusing as they take place in semiconductors.
                    This is real simple to understand if you think about it for one minute. One thing you need to look at is the negistor by JL Naudin. Bedini said in that very same post this is what is happening but Naudin is not catching the power.
                    I am not sure how Mr John is doing it but....
                    If you look at a circiut like the Big Joule Thief (See thread for original schematic). You can set this type of circiut into resonance.
                    If you disregard the Bridged output of the circiut and you use the the DIODE output to discharge into a large capacitor. This will induce the oscilation to grow. IE a negistor effect.
                    Initially you will see a very short oscillation but it will grow, like the negistor.
                    The positive part of the oscillation is created from the power we put in and run through the coil. The negative part of the oscillation comes from the the transistor turning off. It goes Negative.
                    This creates a large potential difference in the capacitor. That can be discharged and stepped down to proportionate levels of voltage creates lots of amperage.
                    For the most part it is simple to understand and see the concept. The hard part is to drive the setup in a fashion that will continually put out with out long period of growth. You gotta find the balance or find the driving mechanism to increase the production.
                    If you still stumped as to what I am saying I'll draw some picture and set a small thing up and film it.
                    Matt
                    • #25
                      @Matt: That sounds good. Maybe you could really make a small set-up for the sake of illustration? I always wondered how to trick negative resistance oscillators into delivering power, this could be a way.
                      • #26
                        This is a drawing. The caps are backwards.
                        Nvisser has got a better way of charging the caps in parallel and discharging in series. Go to the Tesla Switch forums and find it.
                        I'll post a movie with the scope shot as soon as You Tube gives me a link. In the movie the effect is not happening because I did not tune it very well. I'll tune one this evening and get a picture for ya.
                        Matt
                        • #27
                          @Matt:
                          For this to work as you described, the "A" switching would have to happen at the negative halfwave of the collector voltage?
                          How would you drive the switches?
                          • #28
                            zpe_bedini_solidstate
                            Originally posted by Jules Tresor View Post
                            Good morning guys,
                            I just finished replicating the circuit and made a video.
                            Will do some more testing later
                            scratchrobot
                            • #29
                              OOPS
                              I didn't put the note on the thing. Switch the "A"'s on and charge. Turn the A's off and the B's on to discharge.
                              Heres a movie. YouTube - CapCharge.MPG.
                              This is not setup with discharge just shows the thing swinging the charge up.
                              Matt
                              • #30
                                Matt
                                Thanks for sharing, I have to try this
                                Maybe the switching can be done with some more MJL's and a picaxe?
                                What do you think?
                                scratchrobot
