Bizzy's Bedini Machine aka Watson Machine
  • Where can I get a machine?
    • Originally posted by andy007 View Post
      Hi Andy
      The only way to get one is to build one.
      Bizzy
      Smile it doesn't hurt!
      Jesus said,"...all things are possible through God." Mk10:27
      • hello
        i'm new to the energetic forum, and to circuitry in general. as such, i am a little confused about some subjects in this thread, but i can understand most of them.the biggest question i have is whether or not this machine is actually creating energy, or if it is just a very efficient motor.
        • I just want one, it will be great for charging mobiles, laptops etc, but might try a 240 volt inverter on it and see what happens. I have no idea where to start to make one?
            Hi Andy
            I think for your purpose of simply recharging bateries you would want to use a Bedini School girl motor. You can actually buy a Bedini SG kit now which i hear is fantastic and easier than building from scratch.
            The unit I built is more for helping you get off the grid and supplying larger amounts of energy. Mine actually costs less and produces more. The draw back is the space required and the noise
            Bizzy
            • Originally posted by Bizzy View Post
              Hi Andy
              Bizzy
              Yours sounds more like what I want, I can close it up in a cupboard, so the noise would not be to bad, or down the bottom of our path in a garage, I could turn it off at night and go back on grid? I used to be an electrician in the old days, so should get the hang of how it all works. Have you pictures of your and a list of stuff i need, how to wire it etc, sorry to ask all this but I have only just found this bedini thing!
                Hi Andy
                Trust me these things make more noise than a cupboard will hide. The first unit I built was in the basement. It made so much noise, I had to take it apart and rebuild it in the garage and even then I had to surround it with insulated plywood walls(which seemed to work)
                The units are 4'X6' wide and 8' tall. But they work and can produce enough power for all the electrical needs of a typical house.
                As far as a parts list and plans ...it is a very simple machine unfortunately I am having some personal issues which will delay putting it together.
                Bizzy
                  Hi Gorthox
                  The answer to both your questions is yes. It does produce usable energy and yes it is efficient.
                  The key is to arrange the parts in the proper order to do the proper jiob. The transfer swicth i made allows the alternator to arch and produce spikes of 1200 volts or more. If you read some of John Bedini's older writings he describes how those spikes are the best method for charging batteries. That is one of the reasons I started using a batterie to transfer power from the alternator to the motor.
                  However these electrical spikes are used specifically for running the motor. I have also added an additional alternator and transfer switch and the same shaft that gives me usable power. By adding the second alternator i doubled my electrical output without reducing motor speed.
                  Bizzy
                  Bizzy
                  Just to make sure we both understand each other, I am asking whether or not this device is outputting more energy than the input energy. If so, that would mean you have achieved over-unity, WHICH WOULD BE AWESOME!!
                  • Originally posted by gorthox View Post
                    Hi Gorthox
                    The alternator allows for easy energy produce with little drag
                    The switch which allows energy to transfer from the alternator to the motor without being effected by Lenz's law, the switch also allows the transfer battery to be charged with high voltage spikes like Mr Bedini suggested.
                    The bearing system which reduces drag and friction.
                    These items placed in the proper circuit allows the stock 12/24 volt motor to run at a high enough speed to produce enough electricty to power itself. and by adding an additional alternator and switch onto the same shaft with no addition drag on the motor usable energy is being produced.
                    Bizzy
                    • Bizzy,
                      So when are you going to release some plans so that others can replicate your results and we can start the process of standardizing this so lots of folks can build it? I would suggest that you have at least three others duplicate your build as closely as possible, and then once there have been three successful replications, the process of seeing what we can do to build this out of standardized off the shelf components can begin. The world is waiting for someone to be the first to step up and show the way for everyone. I hope it is you.
                      • I volunteer!!
                        By the way, I believe that your video is still set to private.
                          Bizzy,
                          Hi Dave
                          There are some personal issues I need to resolve first. Once I get things in my life settled I want to post the corrected wire schematics.... After I moved the unit from the basement and to my garage and began running it for longer periods of time until parts began to fatigue. The longest the units have run are four months continually until parts began to break, which I was able to correct and actually helped the machines run better. The most surprising element was the removal of the alternator capacitor
                          I have additional video of the rebuilt units however until I get to post the corrected schematics any video would be meaningless which is why I took down the old videos as well. In addition I was STRONGLY counseled to bring them down(enough said).
                          As far as replication I will greatly welcome that. In fact there is one person on the forum who has seen it working and is slowly building a unit as the money permits. I have also been in contact with two other people who frequent the forum who will be visiting me and examing my machine once my personal issues are resolved. (you know who you are )
                          I have been couseled that making the information public is the safest method of protecting myself my family and my ideas, so it is in my best interests to share it.
                          The fact that it is a very simple devce means that it can't be effectively patented. Nor would I do that since John Bedini did it forst already...I just added to his ideas...thanks again John.
                          As i mentioned the key improvements I made were the alternator... the transfer switch.... and bearings. All three of which are simple to build. In fact they are so simple which is probably why they have been ignored in the past.
                          Bizzy
                          • Bizzy,
                            In that case, just let us know when the time comes. There are lots of us who are ready and willing to replicate. This is my full time job, since I no longer work for a living and have to have SOMETHING to do to keep from driving my poor wife insane.
                            • Crystal Free
                              @Bizzy,
                              Your circuit must be a good deviant from the typical SG or SB. Others, including myself, have experience using no cap dump and great efficiencies. However, I have never been able to get more than a few days before my battery crystallizes and becomes total trash. Yet alone, be able to draw power for anything other than the motor/energizer/alternator. I too look forward to your open source disclosure as JB has done.
                              Cheers,
                              Randy
                              _
                              • Originally posted by tachyoncatcher View Post
                                @Bizzy,
                                Cheers,
                                Randy
                                Hi Ran
                                Actually when I was having problems with my parts I went back and simply reread some of the early writings of John Bedini and there was my solution I simply removed the alternator cap
                                Trust me I am doing nothing different than John did. Although I had this idea in my head for many years I am just following his guidelines. Actually if you compare the 1984 machine and the SG circuit they are simliar. The big differance is that the SG is "solid state" and the "1984" machine is mechanical in its switching. It could very well be that is where the differance in your results are...just a thought
                                Bizzy
