New Stan Meyer replication
  • #31
    Pay attention.
    It looks like you are trying to couple, or wrap the wire ON the pipe. That is not correct. If you are trying to physically couple the chokes to the pipe, then you don't have an understanding of what is going on. If you aren't going to pay attention to .PDF replication I gave you, then why ask questions?
    Originally posted by Jeff Pearson View Post
    https://www.facebook.com/photo.php?f...type=3&theater
    here's a pic of what im sourcing supplies for right now. cut away side view. the center electrode is machined solid rod. set up as a dry cell. I will end up needing help with the electronics. specifically driving the fets. one of the freqs I want to use is whatever the center electrode acoustically rings at
    Idea's on how to spec the chokes would be very helpful also
    • #32
      Commercial Buck Transformer.
      Yes, a commercial 100 Volt-Amp 50/60Hz transformer was purchased and I attempted to hook it up while at NDSU. You can see it on the picture where I am posing. The ferrite cores are good to 200,000 Khz, but yes, probably optimized for 50/60 Hz. I did indeed get a rising pulse, but didn't attempt resonance cause I kept burning my transistors out easily with the 12/220 transformer. But, it did work at higher frequencies than 60 Hz. I was probably at 5000-10000 Hz.
      Originally posted by MasterBlaster View Post
      @Jon, Thank you for your previous reply.
      In your drawing, T1 is a 12/220 Volt transformer. Is this an off the shelf device and something special?
      My reason for asking is because standard transformers are designed to work at around mains frequency where as the pulsing circuitry is driving the transformer at much higher frequencies.
      Much Regards.
      • #33
        Not magic.....magnets.
        Not magic, I am using electro-magnets. You keep saying magic. Fix your keyboard.
        Originally posted by tachyon View Post
        that's why I don't like these kind of forums.. you my friend are the definition of a crackpot.. I don't care if you hit resonance with your magic vibes... stop insulting people, even if I was going to share something now I won't. I know there are people like you trying to take advantage of anything it's very bad for you though that you don't care for the world around you.. open your mind you're not supposed to make magic circuits because there aren't any, everything follows the laws of physics and the sooner you start to realize that there better it is for all of us.
        • #34
          you're using electromagnets and doing what?
          The pure in heart will see the light.
          • #35
            If you haven't looked at my design, then don't bother asking.
            • #36
              physically coupling the chokes to the outer tube is just something I'm going to try, so I don't have to tune the outer tube. I play didgeridoo, so I fundamentally understand standing waves magnify energy. It happens everytime I touch my lips to the didg. I buzz my lips to a resonant frequency of the tube and it turns a barley audible lip buzz into a full rich loud sound. how to translate that fundamental understanding into practical use is something else but I get it. As far as the whole system, I agree its not about making lots of gas. It seems to me the HHO content of the total gasses going into the engine only needs to be 1/20th or less
              • #37
                Someone with time, please help this guy.
                Are you really planning on putting the coil wires in the water? I am not trying to bully anybody, but I am not going to give you bad advice and say that is a good idea.
                If you are lucky, you will only burn out a few components.
                Sorry for being rude before. Please go try whatever you want. However, that is not following my replication - if you decide to dunk the coil in water. My coil system sits outside the water. I think most people who have tried this replication might agree. Anyone else have 2 cents in the matter?
                • #38
                  Input a small amount of sound into the didg, and a very large amount of sound comes out..standing waves are performing some kind of amplification
                  • #39
                    energy is conserved the amount of power is changed ΔW/Δt
                    • #40
                      no, im not putting the coils in water I'm setting up the cavity as a dry cell. water gets pumped between 1/2" rod and 3/4" tube. outside of tube is dry. I think it should make for more stable conditions hence less drift of resonant freq.
                      It looks to me like this is how Stans WFC was set up with a big bubbler above the resonant cavitys. I will try it with the chokes not attached to the tubes and make comparisons. at the moment im just waiting to put in a materials order
                      • #41
                        Sounds cool. Let me know if you get bubbles and a signal. I tried a comparison of DC electrolysis versus using the bifilar coil. Without coil, my 2 alligator clip wires melted at 4 volts/3 amps. With the coil system, I maxed my power supply at 30 volts/.25 amps with no melting of the 2 wires.
                        • #42
                          Dry Cell
                          @Jon, You have upset the norm by introducing some true insight in the Meyer's myth. Others failed and developed the "Dry Cell". LOL! And similar nonsense.
                          Anyway to those that matter, it is very clear what is going on with the insults.
                          In any case if you are still here please tell me, in the following video @ 5:48
                          Resonance with a diode.mp4
                          Resonance with a diode.mp4 - YouTube
                          On the right hand side there are some magnet wires that are coiled. Any reason for that?
                          If you move from this form please PM me.
                          • #43
                            The only reason we did that is because the wires were too long. Lew Daily at NDSU said I should get the strands of wire out of the way by wrapping them up on a pencil.
                            So, that's why it looks like that.
                            • #44
                              Don't Give Up
                              @jon
                              Don't give up, as stated in other posts UFO has had his share of Trolls on all of his threads and and even tried to quit once. He removed all of his pictures and videos, but realized that the silent readers were more important than the one or two Trolls.
                              I have tried many circuits and none meet my goal (something that really works) but many of them do rather interesting things. I will be trying your circuit because if only one part (resonance) works (which you showed in your video) then what you have presented is another piece of the Stan Meyer puzzle.
                              Each post can only be removed by the one that posted it, but the moderators can remove anything. I am sorry that one of the moderators injected a stern response to you claims but we all have our opinion and we should just keep them to ourselves and sometimes even if we better information. This is your thread demand your rights!
                              • #45
                                Moderator, please remove some posts.
                                That's great. Would a moderator please clean this thread of tachyon's and Tunguska's (or whatever his name is) posts?
                                Originally posted by mikec_ut View Post
                                @jon
