1 more newbie
I have read this thread, viewed the Utube stuff, and read a bit more here and there.
As I understand it there are basically two designs for producing HHO/Brown Gas.
The use of spike pulses (Stan Meyer) and low voltage cells (Boyce)?
Are the spike pulses, with the use of capacitors are more than 100% efficient? Meaning it produces more energy than it consumes?
I have seen several designs of different types of cells, but is information available about the pulse design (I saw the Peter Lindemann video). Is a design available that will produce enough HHO to run a car engine? What are the problems with this endeavor?
Unknowing
Unknowing
The engine can't even start and battery almost dry. I had to use jump start cable at the end. After replacing with newer o-ring (not the correct spec) and change new set of spark plug, engine able to start but still too much fuel enters into injector. Hopefully my mechanic able to replace the correct o-ring in these two days time.
). The cap fits in the PVC tubr very tightly, nevertheless, if I press my thumb on the output tube, the pressure builds up and the cap slowly comes off. That is why I made two videos, the first one shows that the plumbing pipe material is flexible enough and can withstand the explosion. And the other video shows that you can hold the cap in place by using duct tape so that it can withstand greater pressures and still, if a flashback happens, the cap just flies off and everything works fine. I made several such explosions, the bubbler is still working fine. It is just that the cap shoots up so far in the sky, that it is hard to find the cap afterwards
