@All
Here is an interesting video. Do not know what kind of circuit being used.
YouTube - Hydrogen reactor 12
His experiments independent of ours.
Chris
Chris
The sparkplug IS non-resistive, the wire however, I'm sure has resistance like all sparkplug wires do. I will change to a solid, or at least heavy guage wire (NOT a sparkplug wire) and retest. The cap DOES start to drain after charged, but it was very slow, still showed at least 120V each time I discharged into coil. I will also rearange my momentary switches to ONLY control relays, which should give me less energy escape. I cannot actually read the schematic at the end of Peter's video for the 555 timer setup, could someone post a clear drawing of this?
I will have to send my boss to the electronics store, this would be alot easier to use and allow me to adjust the rate of firing. Does it make any difference whether I relay switch the positive or negative leads to and from the cap? Or do I need a high speed relay, if one exists, that will control both + and - leads simultaneously?
Thanks again for everyone's help, off to do some more testing now...........................................
