Reply to Elias
Hi Elias,
You are quite right, and the only reason I posted that information was because Aaron had done some experimentation spraying salt water on the arc, and wondered about the properties of salt water that caused the water to completely burn off instead of reforming to water after the arc is completed. You certainly wouldn't want to introduce any salt unless you were absolutely sure that it would not leave traces that could cause corrosion and pitting in the cylinder sleeves, cylinder head, piston rings, and valve facings.
With the Kanzius method that I mentioned, the salt water does burn completely without leaving traces, so that shows that it is possible. And keep in mind that Daniel Dingel and Fransico Pacheco both used sea water for a greatly improved Hydrogen generation process to use in running an ICE. You would tend to think that there would be some salt in vapors entering the engine, along with the Hydrogen, but the intensity of the burn appears to take care of that with no problem. Still, I wouldn't suggest that anyone try introducing salt water to their automobile engine unless and until we can verify that the salt definitely is consumed during the burn of the method we are using. Rosco may be able to do some tests with his pressurized bell to determine the outcome of the salt factor, and that would be good to know at differing compression rates.
Hope that clears up the salt idea for you.
Best regards from an old salt,
Rickoff
Hi Elias,
Rickoff
Roman candle effect. I see. Kind of chokes it out, huh? How about a short tube, maybe 1/2 inch or less, to concentrate but not choke the arc? Actually, while I would want to use a tube of probably 3 or more inches in length, the length used for the arc can be as short as desired.
