non fouler plug
Nice! I was thinking of using rubber tubing as an insulator with ID same as OD of middle rod and OD of tube same as ID of the non-fouler. If it could be set in there to withstand the explosion, might be a good cheap homebrew water injector plug.
If the tube had some kind of 1 way valve going to an HHO and water mist supply, the vacuum would suck it right into the combustion chamber on the down stroke. I think the air intake could probably be blocked off totally or almost totally.
The Non Fouler is exactly what Im using! Its scary that some of us are on that Close of a WavePath! Length or whatever....
... so I started eliminating one thing at a time to find the cause and eventually found this simple circuit.
