Working Circuits
Here are some of s1r9a9m9's diagrams which can be found here...
It also relates his findings to some of Tesla's
. I want to duplicate you guys' setup to start testing myself. Could you explain to me the relay used and exactly which posts to hook up to properly execute this circuit. Is it a standard 5 post relay? I have a box full of 40 amp ones if I can use them. I took apart a freebie microwave today and only found a cap that says 1.06 uf 1750 volts, will that work? It had a blocking diode hooked to one side to case ground, but I don't know the rating (is there a way to test it?). Maybe too old of microwave. The cap doesn't look anything like what yall are using, it's much bigger and ancient looking. I have a bridge rectifier to use, 60 amp, and a 1000 watt 12V d/c to 120V a/c with 2000 watt peak surge. Can I use that since I don't have a variac? I remember Peter said in the video he used a 12,000 volt diode at the coil, Does Radio Shack sell those you think? Sorry for all the questions, but I REALLY want to build this, I just don't want it to blow up in my face. Thanks for any help you guys can offer.
