capacitors
Hi all,
Has anyone come across a good source for capacitors? I've been using surplus store Caps for the plasma CDI. Does anyone know about photo flash caps?
Thanks in advance,
Greg
Hi all,
Thanks in advance,
Greg
My time on the clock to assemble the diodes into strings should be less than the difference in price. Leads me to a question for you. Since you and I both have better results with parallel diode arrangements, do you think I would be OK with six strings hooked parallel with 10 diodes in each string per plug? I will probably elect to go with the larger diodes for the final installation to limit the required amount of space to install, along with a little less voltage drop, but first I need to be cost effective and make it work on the bench.
Well, looking forward to your comments on the couple questions above, then it's on-line to order the parts. I'm so excited about the whole thing, I can't even sit still in front of the computer!!
