Originally posted by gmeast
I'm using solid copper plug wires, a cheap HP set from the local auto shop.
I used 18 ga stranded copper wire to my diode sets. I pushed the plug wire and 18 ga wire through the boot, stripped the end of the plug wire and twisted it together with the 18 ga wire, then folded it to the side and crimped on the metal ends (Distributor end). I left extra wire to reach the mounting location of the diode strings (underside of the hood). I don't have video, but I can take some still images if that would help anyone.
All my plugs so far are modified Champions. Extended and sanded springs, and used brass plugs in place of the resistors. I'll swing by the auto shop and see what they have "out of the box".
"Upping" C1 ?, do you mean capacitance ? I have two 47uF in series, halving the capacitance. I can take one out and bring it back to 47.
I'll get better DI water and try a couple different atomizers too.
One safety learning to share, remember this compressed spark with arc farther than the normal spark. I had the engine up and running and pulled a plug wire to connect and external plug for reference. That spark needs to go somewhere and immediately started jumped between diode strings and also to the mounting screws of the block. I provided more separation between diodes and potted the mounted screws.
Thanks for your help,
Timm
So the spark is a bit weaker than it will be when my ordered parts arrive. I will change to a 4.7uF as soon as they arrive via UPS, should be tomorrow. I am using a voltage doubler circuit with a pair of 120uF 330V flash caps, output is 326VDC. This test was performed at 5,800 RPM, decided to go ahead and step it up. I figure it will either GO or BLOW!
There should be NO reason you would need to tach up a Chevy 350 to 5,800 rpm, but IF I do decide to, at least I'll know I'm still stable. As I mentioned in my last post, none of the components were even warm to the touch. This is so much fun, it can hardly be considered work!
This is, by far, the most versatile and easy system available to build. Mods are so easy, practically effortless. So again, thank you and everyone else who has contributed to this technology!!
with a 22uF cap instead, but it heated up enough to feel it just spinning it by hand. Spun at 4,200 rpm for 30 seconds w/22uF, cap was 155 deg. F, diodes were 97 deg. F, bulb (as resistor) was really bright. Could this be due to a real need for a variable resistor? I think I will go back to the 4.7uF bank and see exactly how hot it gets. The caps I got are rated for 5,000 hours at 105 deg. Celcius (221 Fahrenheit). Ordered the best ones I could find. Back in a few........................Mike
