This thread is dedicated to figuring out how to duplicate the circuit that is placed downstream of the HHO Water Bath Cell.
First we must decide which approach was being used, then design the circuit.
Theory # 1: The gas processor cavity used LED light to charge up(down) the protons of both gases and was lit up and synchronized with the High Voltage Pulses. The LED/photon energy was used to inject the "aperature" of the proton that Stan said would open up during the high voltage stress cycle. This was to KEEP the ELECTRONS in the outer orbits making them easier to strip off when they hit the grid of stainless screen that connected to the filament or bulb downstream and isolated from both voltage plates, to consume them. (which happened to be during the off pulse).
To test theory #1: Assume that photons carry a negative charge and that this charge can be used to lower the positive charge level of the proton (++++) to (+++). Now that would mean that if it has a lower positive charge the electrons can stay in their outer (high voltage induced) orbit, a weaker orbit for longer periods of time. Lets also assume that the electrons are knocked loose by collisions with high intensity light momentarily and also because of this weaker bond orbit with their associated proton. That would make the consumption of these electrons possible as they try to source to the positive (electron deficient) leg of the VIC circuit and get set free as heat and light outside of the gas processor, by the filament. (kind of like a mini air conditioning system, think of the EEC grid as the evaporator in your house and the filament as the condenser coil outside, the heat is transferred from the inside to the outside)
( NOTE: Because the EEC circuit was pulsing alternately with the Hi Voltage/LED circuit at a 50% duty cycle, then only half of the gases are processed per volume of fuel passing thru the chamber. To process ALL the gases would theoretically mean great power yields but would require many stages in series, each time 1/2 of the volume left that wasn't processed in the previous stage would be. and so on, making the ratio of processed gases to un-processed smaller with each stage.This is why he spoke of stages for greater energy yields, rockets, etc.)
Here is a schematic circuit to create the alternating pulses:
unless someone can think of a better way...
for this 40106 chip is more effecient than the 555's and has far less to hook up to it. Together we can knock this one out of the park easily.
......How much?
