Originally posted by TRON
Easy answer, you don't. What I am doing with it is replacing the 555's in your set up with this for it has far less parts and is far more effiecent than 555's timer chips. I have to learn how to use the program you posted and once I learn how to use it I will show what I made of your circuit, plus a lot of control mods for engine use. Give me some time to learn how to use it, oaky?
Oh and we are not expanding the oxygen atoms we are reducing their size by stripping electrons from them.
h2opower.
" THe electron extraction process also PREVENTS SPARK IGNITION of the COMBUSTIBLE GASES traveling through the gas resonant cavity because electron buildup and potential sparking is prevented." As we can see, the photon energy is injected during electrical stress on pulse # 61, AND THEN...while the LED's are off and the high voltage is off, the Extractor GRID ( a 2" DIA clear vinyl tube, 4 " long with a stainless steel sink strainer screen inside (hardware store $1.98), connected to a stainless bolt thru the wall of the clear vinyl tubing..for example. maybe with 1/2" pipe thread bushing PVC to 2" O.D. ($.50 each) at each end for connecting the EEC chamber to your gas tubing...) collects the electrons and sends them to the light bulb circuit on pulse #62
and happy testing to all that give this an honest try
