The Golden Tractate of Hermes Trismegistus applied to electromagnetism
    Tourmaline is a crystal boron silicate mineral compounded with elements
    principle of correspondence
    Sorry, still lost
    please expound further
    • scratch the tourmaline idea for now...no use to us here
        I see...hmmm
        does it need to be superconductive? If it does then I say let's go for it.
        You know the double pyramid reminds me of another picture you posted once. Only it had a more fractal application It was the same shape but a few more smaller triangles on the side...come to thing about it it was a star of david, only in a 3d format. It shows waves going out and when coming back in the formed a 3d hexagon surounding a ball (or the atoms, i guess).
        • you mean the jitterbug:
          Jitterbug Transformation
          Along with maximizing structural strength, Fuller's geometric configuration also enabled typically rigid materials to be flexible. In the Jitterbug Transformation, Fuller demonstrated this principle by "inscribing" (building one shape inside another) several different types of polyhedrons. The structure can be manipulated so that the polyhedrons inside morph into different shapes, even though the even though the materials--steel, brass and plastic--don't stretch.
          think of Leon Sprink for the jitterbug
          • Originally posted by shawnnweed View Post
            I see...hmmm
            heres a crazy thought...what if we used a star of david crystal with gold tipps?
              this is not the one...the extended or opened version of it was like this. Yet it started out as a crystal with overlapping fields moving outward, tetragons i think but when the came back in and enlcosed they were locked in place aroud a ball yet in this jittebug shape
              • let's not rush it , let us follow the synergetics principle and start with the sphere from there we evolve to the next level more evolved figures
                and you are right different figures would give different effect , read Leon Sprink and think of the emf egg between 2 electrodes:
                Leon Sprink - Antigravity - patents
                  this is the one. awesome.
                  yet once again you are right, let us walk before we try to run. But for a future idea you once posted a pyramid radio antennae. I thought it was pretty cool. Which gave me the idea for using a neodymium as the center around a star of david crystal with gold tipps. The gold tips could be the radio transmitters, they would face in all directions and be spinning at the same time. It would cast out a perfect round radio signal in all directions. A 3D radio signal.
                    you could start with copper if you don't have gold and easy to make and to test
                    1 rodin coil big
                    1 neodymium
                    Star of david crystal quartz (may have to special order it ) or Crystal ice with quartz dust
                    gold
                    once you have the set up, you'll have to compare it to a Rodin coil alone (itself already a good receptor )
                    you'll have to respect the golden ratio all over the set up from the neodymium ball to the wires of the Rodin coil just like the Ankh set up + a susceptor which is easy to find
                    start with the size of the neodymium ball size from there you'll have the rest
                    • TESLA'S SECRET AND THE SOVIET TESLA WEAPONS
                      © T.E. Bearden 1981
                      In my pursuit of Tesla's secret, it gradually became apparent to me that present orthodox electromagnetic theory is seriously flawed in some fundamental respects. One of these is in the definition and use of φ (Phi ), the scalar electrostatic potential. It is this error which has hidden the long-sought unified field theory from the theorists.
                      please read http://www.energeticforum.com/154404-post318.html
                      The Tom Bearden Website
                        I agree that water should be on the exterior of the crystal and superheated so that it has a low dielectric constant but I do not think it should replace the crystal. The reason is that, in the case of the tibetan singing bowl made of copper, the water droplets resonated completely out of the bowl and onto the surface, which is caused by the 'spinning' application of a wooden dow. When our egg 'spins' weightlessly the same effect will happen within the egg to the water. We need the water to cool the interior but it also hinders us proving an unwanted element; weight however that should become nullified as in the case of the singing bowl by the resonation. However, with quartz crystal singing bowls the resonation also causes light to emmanate from the crystal. In our egg the release of harmonic energy, that resonates from the water and copper, will be absorbed by the crystal which will in turn emmanate light. Light release the infrared spectrum which causes heat, as in the case of the quartz infrared heater, which will heat the water casuing its dielectric property to drop. The UV light emanating from the crystal will cause the quartz to become lighter, when at the right hertz and pressure causing the shift in the quartz, from A to B. The magnetic field when resonating with the exterior copper shell will cuase an electromagnetic field giving lift to the copper and creating electricity which will in turn be transferred backwards backward through the water and into the crystal, which will be stored like a battery. This electricity once it hits the gold plate will be tranmittes out as radio waves which can be absorbed into a resonate copper coil. This can be tranlated back into electricty. This is the chain reaction, or cascade effect we are looking for and expecting right?
                        once the Tesla Egg with the crystal ball inside reaches critical point, the cascade effect will take over and thus the Tesla egg will produce the opposing vortex originally produced by the Rodin Coil.
                        The Rodin Coil in turn will become a receptor (search rodin coil antenna ) which will communicate the signal to the secondary coil of the Tesla coil and passing it to the primary...A well tuned intstrument
                        btw, don't forget the emf egg is recreated in the opposite direction , instead of flowing from down/up it would flow up/down towards the secondary coil...basically it follows the direction of the electric flow
                        • I was thinking of the rodin coil, has anyone wired one up bifilar
                          • a very interesting coil
                            Electromagnetic Coils - portal.groupKOS.com
                            • excellent website Dave , wired a couple of Rodin coils but the normal way...no Bifilar
                              A bifilar coil are two oppositely wound wires......have the feeling it is related to this...
                              instead of seeing the two cylinders try seeing the blue "coils"
                              • Team produces weird optical phenomena - and rewrites the rules of refraction | TG Daily
                                The conventional laws governing the way light moves from one medium to another - from air to glass, say - predict the angles of reflection and refraction based only on the incident (incoming) angle and the properties of the two media.
                                But while studying the behavior of light impinging on surfaces patterned with metallic nanostructures, the researchers realized that the usual equations didn't cover the bizarre phenomena observed in the lab.
                                Essentially, the group's discovered that the boundary between two media, if specially patterned, can itself behave like a third medium.
                                "Ordinarily, a surface like the surface of a pond is simply a geometric boundary between two media, air and water," explains Nanfang Yu, a research associate in Capasso's lab.
                                "But now, in this special case, the boundary becomes an active interface that can bend the light by itself."
                                What makes the difference is an array of tiny gold antennas etched into the surface of the silicon (germinal seed at higher frequency/on a higher scale )used in Capasso's lab and structured on a scale much thinner than the wavelength of the light hitting it.
                                This means that, unlike in a conventional optical system, the engineered boundary between the air and the silicon imparts an abrupt phase shift - a phase discontinuity - to the crests of the light wave crossing it.
                                Each antenna in the array is a tiny resonator that can trap the light for a given amount of time before releasing it. A gradient of different types of nanoscale resonators across the surface of the silicon can effectively bend the light before it even begins to propagate through the new medium.
                                The resulting phenomenon breaks the old rules, creating beams of light that reflect and refract in arbitrary ways, depending on the surface pattern.
                                principle of vibration
                                Scientists use laser beams to control rainfall
                                With laser-assisted water condensation, nitric acid particles are formed when powerful laser beams are fired into the air, with the effect of drawing water molecules together. So far in the research, the molecules that have formed have been too light to fall as rain, but the scientists hope they will soon be able to control the size of the droplets. If that happens, they would be able to determine when it does or doesn’t rain.
                                The scientists said that the technique only works in humid air, not dry air, so there are limits to where and how it can be used.
                                principle of correspondence....
