Tesla Switch
Matthew, "I'm Not yelling Here"
Look it is real simple if two batteries go into series minus the junction drop most of the heat will be in the transistor. This circuit works like a current charge pump. This is all about switching and how the switch works. The Tesla Switch is nothing more then a dual charger of which you can take energy from. You all must understand I do not like to use the term current because this is just the dissipation of the potential in the system which is the voltage. You want to use the least amount of current to charge the batteries, the batteries understand what the signal is since your scope can not see it. What you will notice is a sharp funny looking square wave, not what I have seen so far, I will try to take pictures for you all. The minimum scope must be at least 100Mhz to see anything. I was showing Peter yesterday when you get it switching right you will see the scope go negative 1 1/2 times the input, This would give you a COP of 2 anymore then this, John would not be around to talk about anything. I will try to draw it for you. The 50% duty cycle will do this, and you can run this down to 10% if you want. Try just building this simple at first so you can see what is going on. Timing is not the key the switch is and the device used. Right Leroy Good Job.
JB
JB
