Tesla Switch
Gang,
I will post a charger that Energenx makes for Solar, as everybody knows the efficiency of the panel is limited because it can't charge the battery correct. The solar panel does not work with white light it only works in the far inferred range. With a little engineering the panels will charge batteries in low light. The best way to see these gains is when you put nothing in. If you look at all the circuits I have posted you will see what John is talking about. Everybody should be working on what I call the Solar oscillator. The Joule Thief, independent invention from the SG energizer, but one in the same. I have seen Solar oscillators charge in the moon light. Once the panel is in low light your dead in the water as you can not charge anything. But if you take the low light convert it with an SG circuit you will charge batteries in low light. The Tesla Switch can also be made to work this way as I have done this many times, it's all about switching.
I will post what I can to help.
JB
Gang,
JB
