  • lightworker1
    I can see the headlines now, Col. Tom backs up UFO. HaHa HoHo HeHe.
    Dana
    Nikola Tesla
    • Hello Sampojo...
      Originally posted by sampojo View Post
      Here is a few questions for UFO then.
      1. So this motor must have a total of 8 BRUSHES ++-- motor and ++-- gens ?
      2. For wiring, do you connect the input power motor + terminals together onto the power?
      3. Are you and machine building an asym gen and if so, where approximately in the thead is the best place to start studying it?
      • Yes, that's correct, four top, four bottom, Two Positive Motor Top, Two Negative Top Generator, Two Negative bottom Motor, Two Positive Generator at bottom.
      • Motor Parallel, Generator Series, Motor Two Positive attached, Two Negatives attached.
      • Generator link http://www.energeticforum.com/renewa...tml#post205259
      I want to try to convert a salvaged induction motors to a generator to run off of the first 10-pole I build, the one I have is shown in the first pic, before I invest 600 in a Mecce Alte.
      I have a question about what generator output (harvested CEMF) looks like on an O-scope. I am assuming it is similar to BEMF from any non-motor coil, which must be very spikey high voltage, ringing like crazy, and decaying rapidly, to give a simple voltmeter reading of a "steady" 18v or whatever.
      Give it a try, test it yourself and see what it looks like.
      UFO or Machine, is this where the diodes and caps come it to improve the quality of the generator output? Is it possible to apply a FWBR to get more power in this situation?
      Thanks!
      Joe
      Sampojo, all your listed questions above are on this Thread, and if not here...on My First Thread, It took me a while to search back to find the link I posted...You could have done exactly same thing.
      You will have to make a replication first then start drawing conclusions/assumptions...the fact that first one did not worked out...does not mean you are gonna try for a more complex one and it will work "this time"...
      You have to start like the rest...by simple, less complex models.
      You have not done that and you want to jump into other clever approaches...like an Asymmetric Generator?
      It does not work like that in real life...in the event you fail first grade...you do not ask teachers to "move you ahead" to Third or Fourth Grade...and expect They will do it for you ?
      Same, exact thing applies here.
      • Thanks UFO for your reply
        Sorry to be impatient, so much to learn. But things looking better here actually, left off insulating washer on front of brushes! I want to make the RS a real motor FIRST (grade?). ;-)
        Up, Up and Away
        • Hello UFO,
          Thank you for that drawing and the detailed explanation. I perfectly understood what you said so 4 stator poles it is!
          Gotta get busy now and finish up this motor............
          Lester
          • Dana's "Leemo"
            Why do I keep getting the feeling that Dana is going to do a drive by in his Imperial powered "Leemo"?
            It's taking almost too long for the next UT.
            bro d
            • Comment
              • Donald
                Everything is coming along fine. After preliminary testing I felt that the motor should be tied down to something so I started making a jig for it and doing internal motor inspections and better bearings. Half way thru the jig, the welder broke. I got a new one and finished the jig. I am waiting for high amp toggle switches and such. It took a day for the jig paint to dry so I made a control panel for all the switched and the positive power cable switch. I am taking the rotor back to the shop for another soldering as I think the first was too lite although nothing went wrong. If you have a feeling that it may need more work, you should do it as that motor is mean. After that the 2400 watt generator head goes on. I have also been busy at work lately and not getting home on time so hours have been shorter. In the end it will be worth it and you will see videos and pictures as well as data.
                Dana
                Nikola Tesla
                • Originally posted by prochiro View Post
                  Donald
                  Dana
                  Thanks for the report Dana.
                  I wrote "Leemo" because UFO would probobly pronounce it that way.
                  No body laughed yet.
                  bro d
                  • Sorry to tell you I will postpone my MY1020 motor modification because of private issues. I will continue to watch and help at pulsers as well.
                    JohnS
                    • Hello UFO, all,
                      I didn't want to waste an opportunity for tests & measurements so I went ahead with 2 magnets initially. Will go for 4x magnets later on. I don't have suitable brushes yet so I just held the wires between my fingers and let her run. I got 6,600rpm at 3v input.
                      Here's a short video, pardon the poor focus: MVI_0726_mpeg4_zps5eee84ab.mp4 video by Navigator444 | Photobucket
                      I couldn't measure input current because my digital ammeter goes haywire with the motor. Will hook up an analog meter once I have some brushes mounted. I'm still trying to understand the rotor poles' position relative to the 2x stator poles but it's good that it spins for now.
                      It runs fastest with the brushes positioned as seen on the video (the pole pair's bisector is aligned with the commutator elements). It coasts along when power is removed and there's very minimal cogging from the magnets. Gap from rotor to magnet ~0.5mm. Again it's still a Torqmaster winding.
                      Thanks!
                      Lester
                      • Looking Beautiful!!
                        Originally posted by Lester444 View Post
                        Hello UFO, all,
                        Thanks!
                        Lester
                        Hello Lester,
                        Wow, I am impressed, looks awesome, neat, very neat!
                        I want you to notice...on this motors, since you are doing this "hand brush tests"...to start the motor...then start getting just one of the "wires-brushes" a bit away from commutator...just a very tiny bit...so you get a very small air gap...and watch it arc, and still spins...now have to be the exact gap though...
                        Also, give it a try with some Carbon Fiber brush, just like wire...
                        Great, and that is the Two Stators...wait till you make the Four...
                        Great work Lester!!
                        • Lovely Green lady,
                          Hello UFO, all,
                          Thanks!
                          Lester
                          Hello Lester, looks to me like you had the green lady pay you a fleeting visit on your red wire, all she wants to do is get out of jail you know!.
                          Regards Cornboy.
                          • Originally posted by Lester444 View Post
                            Hello UFO, all,
                            Thanks!
                            Lester
                            Imressive! Wow! This result on first play!
                            Regarding your ammeter! You can use it though. Get a transformer (for extreme use a MOT) and short circuit the HV coil.
                            Insert along plus lead from PSU:
                            - Ammmeter
                            - low voltge coil of transformer
                            - severe capacitor to GND
                            - connect motor +
                            As the choke is lazy in matters of current change it gives your ammeter the chance to display true average current. The caps will supply sudden current request for motor.
                            • @UFO,
                              I did see some purple light in between brush and commutator. It is strange to me that I consistently get a lot of this purple light on the POSITIVE brush (red wire) only, none on the negative brush, even if I swap the polarity around. Nice to have an open system that allows a lot of flexibility and visibility.
                              Yeah I wish I had some carbon fiber for the brushes but that item is extremely expensive over here. I do have 2lbs of powdered graphite but don't know yet how to make it solid again. Perhaps some pencil lead will also work? Will try it later.
                              @Cornboy,
                              Yeah she's roaring to get out. I think she likes me!
                              @ JohnS,
                              Thanks for the tip!
                              Lester
                              • Spark Gap
                                @UFO,
                                @Cornboy,
                                @ JohnS,
                                Thanks for the tip!
                                Lester
                                Hello Lester,
                                Radiant could manifests in either Hot Positives or Negatives, it had to do with the Magnetic Orientation of Your Rotor (How it is wound) related to Stators and the Rotation sense...However, when you have steady brushes on...or pulse it electronically...then you may see it different.
                                What I was referring to...is to make a Spark Gap of any kind...it could be even a couple of old carbon brushes...sharpen the point like a pencil, and be able to adjust gap very accurately, and fixed to even a circuit board perforated Bakelite.
                                What I wanted you to notice, is that this type of Motors, once they are running, have a very clear arc-spark through an air gap (once all coils are charged and amperage drops, reaching a steady cruising speed)...The Spark gets to synchronize with commutator switching perfectly after a little time running it.
                                The only thing is that it could get really hot...and in some cases of higher amperage, the carbon small brushes could get red hot.
                                Yes, it is great to be able to operate this machines as open systems...
