hi Gyula, ill tell you about where i live first. i live in the middle of the bush at the bottom of a gully, surrounded by mountains, my house is only 30m above sea level, we have 3-4 natural springs on our property which we tap into to fill our water tanks, we have no mobile phone reception or radio, we had to spend alot of money for a special antenna so we could get a decient tv reception and we have a satalite dish to recieve internet.
all i have done is use the ideas that i have gained from what i have read about teslas work and also others on the internet. first i used my metal roof as an antenna which was joined to a air cored ring coil and it was grounded to a copper tap, the system fed the energy back into itself continually, if i shorted it out so there was no energy in it, it gained the energy back very fast, after 5min it climbed to 30DCV and after 10min it was up to 45DCV and 80ACV, when i tryed to messure the amps it unloaded the energy into the meter and blew it up
im not sure how high the simple system will climb to? ive dissconnected it from my roof as i think it is not safe to have that sort of power attached to the house and now i have a small 900mm x 1300mm sheet metal for an antenna
before this i eliminated any sort of leakage from mains power by doing tests with my garage roof and other metal objects
without the large metal surface (my roof) it does not hold the same amount of energy, now the system normally sits around 10DCV to 20DCV
my problem is that i dont have an electrical back ground, im just the sort of person that allways asks "why"? so i have done all this out of interest, i dont know how to make this usable and all i have done in the past is light up led lights (26 at once and all full brightness) and nearly had an electric motor running at 1 stage
i need to be able to use the energy with out triggering the system to fully discharge, if it is let to sit it will gain energy, ive now put that aside and im trying to learn everything i can about wireless transmittion so 1 day i will be able to tap into it wirelessly without disturbing its capasity.
i believe teslas personal systems were self runners, they did not have to create alot of energy so mains power would not be needed, even if he used a battery to give it its needed excitement it could be easily recharged by the system, wardenclyffe was designed to create huge amounts of energy so a large amount of energy was needed to create a continous amount of energy for the worlds use, and also to power what the tower was capable of that will be forever unknown
i believe the energy is allready in the air and earth, we just have to make it usable
Gav
im not sure how high the simple system will climb to? ive dissconnected it from my roof as i think it is not safe to have that sort of power attached to the house and now i have a small 900mm x 1300mm sheet metal for an antennabefore this i eliminated any sort of leakage from mains power by doing tests with my garage roof and other metal objects
Gav
