I haven't heard a peep from mine since I mounted it, but I've yet to load it so can't say definitively. My guess is no one knows for sure yet, but I believe its emission of infrasound is neither significant nor comparable to that of traditional designs. There's no regular beating of the medium going on as with propeller ("wind turbine") or vertical axis devices. I can see it possibly whistling if the vanes are made small or tightly spaced enough, but how irritated do you tend to get after listening to your bathroom fan for a while? This design's got to be far less annoying than that even because it's being driven by the medium instead of driving it.
12,000% More - Open System Physics & Thermodynamics by Mike Waters
I had to replace my gas dryer's motor last week because one of the sealed bearings was squealing like a stuck pig. The motor drives an impeller like what you've shown above, only they're a bit larger and plastic. Nice, but - Plastic. For a very hot application. Whereas - Metal. The material of choice for drying relatively cool, wet bathrooms. Go figure. ?Originally posted by Dingus View PostThis looks like an ordinary impeller fan with a somewhat concave cone in the middle.
I'd like to try this out, maybe use it as a water turbine in the future.
Anyways, been thinking about your electric scooter application. Seems like it would be cool if someone could mount a similar little impeller on the back of a pickup truck or something and see what happens. Drive a little generator with it. Take measurements. Report results here.
Merry Xmas
Here's a guy thinking along those lines:Originally posted by grumblenuts View Post...
Merry Xmas
Sure, clearly a few similarities. Thanks for the link and common interest
But
sorry, smells like mostly crap to me and looks like nothing actually novel. Published well over a year ago? Here's an idea, drive the thing across the country... then start bragging about it... after a smidge of that wishful thinking actually bears some fruit.
Meanwhile, I can't seem to stop thinking about that dryer impeller now and the motor... Maytag/Whirlpool in case you're interested. 1/3 HP, 5.5A, 1725 RPM. Turns the drum with a belt pulley and the impeller directly. 1725 RPM is 28.75 revolutions per second. That seems pretty quick, but ever feel a dryer exhaust? Not all that powerful. So could the wind sort of do the reverse? And how does the motor stay cool while trapped inside that heated cabinet?
I haven't seen exactly that set-up, but I imagine the fan pulls the fresh inlet air over or even through the motor. Interesting that the heat from the motor can be used by the dryer and therefore not wasted.Originally posted by grumblenuts View PostAnd how does the motor stay cool while trapped inside that heated cabinet?
The motor does have a rudimentary fan cast into its stator, but fresh air does not get pulled over or through it. Actually, there's no "fresh" outside air involved at all. Room air is sucked into the burner or electric heater, then it goes through the drum to dry the clothes, then the moist, semi-cooled product is passed through the lint filter and on into the blower housing. Then it gets blown outside. The motor remains isolated from all that, performing long, continuous duty cycles while trapped inside the warmed cabinet, year after year. Some illustrative pics:
Nah, there's no "cooler nearby air" and no "in" or "over" going on. As one might expect, Google image searching reveals that the inlet air is supplied through rudimentary slots, seams, and/or holes, sensibly hidden from view, and fabricated seemingly anywhere in the back panel.
Considering this evident lack of engineering concern over keeping the motor cool, beyond the fins cast into the rotor (not "stator" as I mistakenly said earlier), is why I brought this up.
I suppose the motor does help heat the drum and/or vice versa, but neither helps the motor last which was my concern.
Not proving to be a very productive diversion yet, but thanks for the attention, compliment, and sharing of your perspective
Another thought regarding putting a cowl around the thing. I'm thinking sort of the opposite. Vent the backside up the mast and out some, perhaps venturi shaped, contraption above the rotor, using the wind to develop an even stronger vacuum there. In effect, create even more suction behind the rotor, causing it to spin faster and/or with more power.
Construction
Thin plywood back 4 x 4 ft half sheet .. light wood blades ceder ? Pivot pins or drywall screws long as you can get ? May have to make a concrete mold for front flange for fiber glass lay up. Same for internal cone.. To get the flange use a plywood cut out with a 3/8 to1/2 copper tube layerd on the cutout held with 5000 pound epoxy turn cut out on a vertical 1/2 pipe to mold concrete then sand smooth surface and wax for lay up. Vertical section same . this was used to make large 8 ft diameter fiber glass parabolas . make a steel rack wall and mount many into it and pull the accumulate power . really would be nice to mold the hole thing but maybe off the shelf will work.. Any ideas to make it easier would be appreciated. How about a very large 3D printing machine?? With imbedded fiberglass in the excretion.
I think fiberglass is a great way to go if you have that skill. Especially to mass produce. Implies knowing exactly what you want in advance which seems a bit scary. Thin plywood and cedar will do fine for prototype/experimental purposes. Prefer polycarbonate only because I happen to have tons of scrap from dumpster diving and it's transparent.
8 ft diameter now seems about ideal to me. Far as making it easier, I really think my painted plywood flywheel is a keeper. It helps keep the thing turning steadily in varying winds with no apparent detrimental effect upon its responsiveness to wind direction. But it also serves as a nice, solid base to build the rest upon. Holding stuff in place with drywall screws, for instance.
Grumblenuts
I wasn't completely true on the 8ft dish's it was 12 ft and they used small mirrors of plastic squares .man can you imagine the heat stand in front and try to fry a burger ??? You'll melt the pan!!. Go blind!! .I figured out a way to cook with out the issue .use a thermal diode at the hot spot raped with a steel tube and bring it Thu the dish .using it to pivot it with the sun. No light no heat out OU control. Just you and the hot end of the diode tube in a room .diode tubes are just a steel tube sealed at each end with a carrier fluid inside and vacuumed out.the heat locks just below the boiling point of the fluid. Like water it would be 99 deg Celsius. With sodium the hole tube glows like a neon red.will work up to 60 ft.you cold cook or run a Stirling motor heat the house bake all away from the disk out side .organic fluid breaks down with time.from the heat.: jim
That sure sounds like fun and something to keep you busy for years to come. Well, to bring it back to this windmill design, I say 8 feet now seems ideal to me because 10, as I had been planning, let alone 12, is just too darn scary to contemplate mounting on my garage given the winds we get every so often here.
As discussed previously, or posited at least, the effective diameter is greater and only grows with higher wind. Mike Waters says smaller ones are equivalent to significantly larger traditional designs as well. Making an 8 ft mold for fiberglass has got to be a lot easier than one for 10 or 12.
Just noting that I've now detected clear evidence of a flaw in my design/construction. Somewhat ironic that after saying only a week ago, "the thing turning steadily in varying winds with no apparent detrimental effect upon its responsiveness to wind direction", I must report already that this is no longer the case.
I began suspecting a problem a couple days ago when it didn't seem to be following the wind as easily as usual. This morning though there's no longer any doubt. It's still spinning fine and quietly, but making clear creaking noises and being noticeably reluctant about changing direction. Sticking.
This after more than a week of rainy, unseasonably warm, soupy weather. I suspect simply inadequate handling of downward or gravitational thrust, but my regular bearings may need more protection as well. If the thing requires maintenance more than once a year I consider it a failure.
