Originally posted by Robert49
Because the bulb was connected to the right hand side, A1 measured the total input (1.8A) and did not measure the sum of A2 and A1 (2.7A), right? So the input power can be calculated as 50V*1.8A=90W in this test. So I agree with your test.
HOWEVER, in your post #1584 you wrote this:
"If I put the bulb wire before A1 , I get 3.55a on A1 which means the effective power going in the motor is 130v x 3.55a =461 watts ??"
And this is the input power calculation what I do not agree with because in that setup you considered the SUM of A1 and A2 when figuring out input power.
First the bulb was connected to the right hand side of A1 and input current was A1=2.2A from V1=130V and A2=1.35A from V2=230V. So in this latter case input power was 130V*2.2A=286W, ok?
And when you put the bulb wire before A1 (i.e. to the left hand side of A1) then A1 showed 3.55A which is okay that it showed the sum of the earlier values A1 and A2 but you cannot use this summed current for calculating input power: this is what I do not think is correct. How would input power change from 286W to 461W by merely connecting the bulb wire before a current meter? A good current meter must be a short circuit for the current, it cannot cause such a huge change in power.
Is this okay? Maybe you meant something else with your question and I misunderstood.
Thanks, Gyula
my bad.
