Originally posted by Jetijs
I think you pretty much explained: it must be the bigger change in inductance that causes the difference in current in the first case when the air gap is bigger. In case of the smaller airgap with the V2.0, the inductance change must be much less, may it sound rather strange.
Maybe you could use a self-inductance meter to check the changes in the uH-mH values when you rotatate the rotor slowly by hand into alighment and then out of it?
The idea of chopping up the ON time into many short on-off pulses is a good one I think. This way you can reduce the negative effect of any changing self-inductance and create a more efficient recovery possibility of the flyback pulses. You may have heard of Doug Konzen's recovery circuit that could be used with your chop up circuit, see pages 3-4-5 in this PDF file:
He connects the AC input of a full wave diode bridge in parallel with the S1 switch (which switch would be the chopper switch in your case I think) and he uses another switch in series with the AC input of the bridge, slightly retarded in time wrt S1, see his Figure in page 3. I have not tested this but he has built several such recovery variants and described them in his yahoo mail group EVGRAY : zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz where some members built them.
The PDF file is collection on his hints.
Of course, you surely can use any other recovery circuits, the reason I mention this one is because I think it nicely fits to your intended chopping solution.
rgds, Gyula
Im going back to using a single pulse, but will be using the collapse a little differently. Too early to say much about it, but it may offer another option.
