Earth Battery SG
  • Very good points on the order and the priming.
    • Originally posted by Iotayodi View Post
      thanks I what hoping this will get people away from thinking in the old way of just current from the chemical reaction, I have not used any salt as yet but that would help with the amps if i needed them,
      I think the switch can be done by a sg or a little fan in the wind sorting the coils,
      • I love it
        setting up a condition in the aether that self sustains, producing the voltage potential with aetheric stress, without using chemicals, and deriving electron movement from there.
        Have you done a clear drawing of how to build each unit? Might find a use for my back yard after all..
        Love and light
          Love and light
          also ben got infomation saying, that if you have voltage and a vac tub you can use the sunlight to supply the amps! more on this later,
          build is easy zinc rod or zinc plated box with cotton to insulate the windings, put in a plastic drain pipe with a sealed base with holes to let the water out (like planting a energy flower)fill with earth water it and stick in the ground.
          love and light 528
          • YouTube - earth battery coils 17
            latest on the coils
            • 8 coil plus real ground I get 7.2 volts charging a 1farad 5 volt cap that runs a small light bulb, this is passive charging no pumping yet!
              love and light to all
              B
              • Originally posted by Bodkins View Post
                love and light 528
                Sunlight on early cat's whiskers radios (ie using Galena) caused better reception, ie more radio sensitivity
                • YouTube - earth battery light bulb
                  I lot of hard work for a flash! but it will charge passive so what about pulsing?, Im trying to use the Sg fan to pump the energy around with a cap on the front end so i can spilt the earth battery across the cap and power battery.
                  what i have now is basic, not really got the volt up to a point i can dump into battery
                  any ideas?
                  • you star now stick up a picture with a big happy smile!
                    led solar panel earth battery
                    love and light x
                    • Series Earth Battery
                      Hello Guys and Gals(Jeanna) . Just a quick note that Jim(electricme)has Successfully Series connected his earth battery's to produce more than 80 Volts dc at a considerable Amperage . I know it could be Done . I personally can get 15 milliamps off of My carbon and magnisium rods . I sell sets on My web Site (www,sunpowerwindpower.com) in case you don't have a supplier . Copper and zinc do not work well for me in My ground here in NC . I have been Lighting up Joule thiefs from day one manm many months ago producing whiye light continuiuus . I recently pulled one of the Mag rods and there is very little wear after almost 9 months .My jt produces any voltage i wish but i use one of them to keep a 650 farad 2.7 volt Ultra cap full for experiments .I am able to power radios and lights and small One Magnet Bedini Bearingless Rotor . With one volyt and 1 milliamp . Needles to say this one is a self runner with 5 extra coil gathering electricity from the spinner magnet and also produce light and charge up a few super caps to boot . motors with one earth battery directly with only a small 2000 MCD cap in parallel with them .
                      Ok good work . i would say more but i am on dial upand it takes way too long to chat these days now that i have no High Speed availible where i live .
                      Take care GodBless and Good Experimenting ..;
                      Fusionchip
                      AKA Gadgetmall @ ou.com
                      • Spaceborne observations
                        Originally posted by jeanna View Post
                        I am seeing up to 67mV pulses at a rate as fast as 5.5Mhz. They are quite sharp and they are on a carrier wave. I also see it in a 'fractals' light, because the waves repeat themselves at different resolutions.
                        jeanna
                        Hi Jeanna,
                        I would like to point you to this paper which might explain why 5.5Mhz:
                        1965IAUS...23..309H Page 309
                        See figure 3 on page 313.
                        Spaceborne observations of radio noise from space done
                        in the 60s show that most of it falls in the 1Mhz to 5Mhz
                        range.
                        fyi
                        • HA
                          ET radio stations eh?
                          I think the most interesting part for me was that these frequencies were not the same every day. Most of the time they were 2.2Mhz to 2.4Mhz and some days 2.5Mhz.
                          I think there must be a lot of radio waves everywhere and I do not mean those from radio stations on earth. I am meaning that every light bulb or dishwasher etc gives off radiation light or heat etc. That radiates out and across. We twirl around etc.
                          I think some of it is us bumping into our own past radiations, and then of course all the stars and explosions in space keep going radiating outward. We must be bumping into them too.
                          I just didn't ever see anything higher than 91mV from my EB plus 2 stubblefield generators set-up.
                          I never did make those stubblefield generators big enough, I think. I will get back to making more.
                          thank you,
                          jeanna
                            YouTube - earth battery 7
                            still working
                            i cant get the scope down to the allotment no power sorry Bill
                            what I do is to wire my electrodes to a 50 ft extension cord, one on each prong, and then run that into my house and hook that up to the scope. Much easier than packing the scope outside. Electricme (Jim) told me of this little trick. It works just fine, unless of course, your electrodes are way out there somewhere.
                            Bill
                            • Originally posted by Pirate88179 View Post
                              Bill
                              have your got a 4 mile extension cord saving for a inverter
                              Richard
                              • Earth battery booster?
                                might a salt water battery leverage/multiple energy extraction if paired up
                                with an earth battery?
                                Don't take these references "as-is" .. but how could they be reconfigured
                                or redesigned to be used with an earth battery?
                                Might a tube tightly packed with crushed activated carbon for the
                                anode and cathode with salt water
                                at one end of the tube and fresh water at the other end of the tube work without flushing / total
                                replacement of salt/fresh water?
                                They claim 1 Kw per liter of water is possible but have not obtained that yet.
                                References:
                                12V 40AMP HOUR salt water battery
                                Amazing 12V Saltwater Generator
                                Physics Buzz: Electricity From Salty Water
