Welcome Kentman to the thread and thank you for your input.
I must admit here that I was posting to the thread before I seen Lloyd Tanners video. I was looking at Ricks drawings and thought the friction rotor was running horizontal not vertical as in the video. Non the less both would work. After reconsideration I believe the vertical now to be the simplest way of reconstruction and will take the freedom here to input a new idea to bring the rotor into better communication with the boiler base without it having to be directly inside the boiler.
I am thinking of machining the top of the rotor as seen in Lloyd's video with small "races" like for a bearing...and also on the boiler base. Then uses small balls that the boiler base and rotor would be in contact with. Thus providing additional friction and heat transfer through the steel balls to the bottom of the plate. I am thinking of many concentric and ever smaller rings of races so many balls could be used. Would BB size balls work?...and if the BB's wore out they are cheap enough to replace. So i would not lubricate the BB's in communication between the boiler base and rotor top.
Any input on this Idea would be most accepted.
Thanx...24
Thanx...24
