motor
Hi Mike,
I need some real magnets before applying it to a motor. I'll probably use my bicycle wheel and put magnets every 90 degrees for starters just to make it run. I find the 2n2222's a little tricky to get to work as well. I didn't try using a winding around the coil body to trigger it yet so that may help.
I'm very interested in getting the effect at high frequency and not necessarily to run a motor.
When I used one of the recovery windings on the trifilar when it was setup as a pendulum...one single pulse recovered 175 volts in the 4000v/u2f cap...not much but there is no doubt with everything matched up and tuned you can get quite a bit back.
I can see that speed a little bit slower but power consumption is down.
The only way now I can consider power consumption by checking 2n3055 temperature and it is not heating up.
