SW and Totoalas and All:
I'm still doing tests on charging two AAs in parallel from two AAs in series. I've noticed that the Leds lights Do Not drop their light intensity immediately, at all, when connected to the Jtc batteries in the circuit, this way. But, once the charge batteries run down, the circuit is not really charging anymore. As it takes 1.5 times the normal battery voltage to charge them up, without a having a fluffy surface charge. Frequent swaps are needed. I'm still feeding-back to the positive rail, as my set up doesn't like the feed back to the negative rail.
There is No secondary induction in any of my Jtc, and I'm am a bit frustrated about that. As I don't get to see the real magic in the circuit. Although my Jts do go a long time on each battery swap or charge cycle. They seam to have more current and less voltage. I still have to bump charge them every so often, to keep them all charged up and running well.
The only way that I can see to keep the system charged up and running at its optimum, without losing its operating frequency, is to connect the Jtc up to a solar panel and a storage battery. Therefore maintaining a steady operating voltage that will keep the Jtc at a steady 6 volt charge. Otherwise it's a losing battle, as sooner or later, all the batteries run down, and though the Leds are still on, they are dim. Boring...
Hopefully this can be overcome by using a very strong running Jtc that can more than make up all the loses, like lighting a bunch of Leds at the same time.
A self charging, self running joule thief that can also light a few hundred Leds all the while, would be something to see. We're getting closer...
Good luck with your tests guys.
NZ
NZ
