Hi Mart. It's a great setup you have there
I would go up in amperage for those 200Ah batteries. I could charge my 200Ah battery to the max in about 20 hours with 5.2A input at 13V. You have to adjust the base resistance so that each transistor handles about 0.5-0.7A, that should handle the heat. My transistors are just slightly warm, of course they are glued to a small aluminum plate, that also acts as a heatsink a bit, but I am sure, that they should work the same also without the plates.
Mart, where did you get the CBA2 new software? From their web page? Is it for free or does it cost something? And can this new software be used with the olds CBA tester?
Thank you,
Jetijs
BTW, my 60Ah battery has now improved to 18Ah
Thank you,
Jetijs
Think I will create my own 10 amp load with my crock pot and then use the charging feature to measure voltage.
... work well for me and charging very fast..., I use 2 tri-filla coil and draw 2.5Amp
Selamatg
