Rodin coil.
@Twinbeard
The diode is a fast switching barrier diode to handle high frequency. It has a metal contact at one end of the silicon junction and discharges as fast as it charges. The diode is stripe to positive.
@Rave154
Carry on with the Rodin coil, you can experiment with these different kinds of output coils for the high rate of spin when it's done. You can't build a better coil for a no bearing spinner. My unorthodox approach works well too, because sometimes the spinner can act like it has a mind of it's own.
I contrived a new rotor setup. The small 1&1/2" long carbon rod axel and 1" neo tube magnet are suspended between two slightly larger erector set gear wheels on each end. When the carriage is seated neatly inside a small wooden cup, the whole assembly can rotate 360 degrees, and spin very fast on it's single central ceramic bearing. This allows the rotor a degree of self adjustment. I ran it between the power and the air core output coil looped back to source. The power ran evenly, but no gain again for the primary without the magnets in the output coil core. Naturally, the primary charging returned when the magnets were reloaded into the core. The speed is highest with the cup spinner held four or five inchs over the air core power coil. The spinner has to be started directly over the air core, then raised to top speed height. Then the output coil can lower down onto a roof over the cup. This seems to work very well. Next step is to wind a second output coil identical to the first, and position one on each side. I plan to also follow through with "Twinbeard's" 1 farad, 20v capacitor upgrade when I can afford to, in a few weeks time.
@Twinbeard
@Rave154
maybe you guys could benefit from some resonant tuning receiver coils etc. to boost your power recovery??
