Originally posted by chuck H
Bedini Earth Light
This is the conversion of gallons to liters, and I know that without a chart, what it has to do with cups . As I understand 1 cup is about 200 grams, then how I can dissolve 400 grams of alum in 200 grams of water, too much of alum. I still did not get it. Would you explain one more time please.Last edited by hiops; 05-15-2011, 01:06 AM.
Originally posted by hiops View PostThis is the conversion of gallons to liters, and I know that without a chart, what it has to do with cups . As I understand 1 cup is about 200 grams, then how I can dissolve 400 grams of alum in 200 grams of water, too much of alum. I still did not get it. Would you explain one more time please.
1 cup of water is 240 ml. Its a volume conversion not weight conversion.
Matt
Anyone else seeing voltage increase at noon on their own cells? One of my cells gets its best voltage reading around noon. I thought it was temperature at first because my cells are affected by temperature but at noon it was cooler than it is now in the afternoon.All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
I've noticed that the cement batteries tend to lose their output ability as time goes by. They started at almost 2 volts per cell and after two or three weeks they have dropped to 1.2 volts, but under load it is more like 1/2 volt.
The current that started at 65 mA per cell has also dropped to less than 50 mA. So, it not looking too good, as that reading is on my best cells.
I'm making some more new cells now to see if the output can be increased, or at least kept closer to where they started at when they are first made.
I'm using the tall aluminum cans, and almost a pound of copper wire in a spiral and inverted through the coil, beach sand, and baking powder, that's all. I'll let you know how it goes when I finish them tomorrow.
Can someone let me know what to do when there is no Attachments Icon???
I can't upload any pictures now...
I don't know if this is the right place to ask and I'm having trouble finding out myself because google searches seem to go round in circles and lead nowhere, but I was wondering, can the circuit in the first post be used in an "earth battery", using rods in the ground like Aaron's video here instead of an artificially constructed cell like John Bedini has made?
YouTube - Earth Battery (rods)
I'd like to convert some of those useless solar garden lights to run off an earth battery
Originally posted by dR-Green View PostI don't know if this is the right place to ask and I'm having trouble finding out myself because google searches seem to go round in circles and lead nowhere, but I was wondering, can the circuit in the first post be used in an "earth battery", using rods in the ground like Aaron's video here instead of an artificially constructed cell like John Bedini has made?
The Earth battery that you showed was a galvanic battery, this is not what John Bedini was going after. Galvanic battery will eat away at one of the plates due to the dissimilar plates touching water. John and many others are going after a crystal cell, which is like a galvanic cell but doesn't get consumed and outputs a continue power. But that video does give you a great place to start off at and learn. Using his setup in the video it should run a LED for a long time but will die when the aluminum curtain rod gets consumed.All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
A ferroectric generator patents
ELECTRIC GENERATOR - Patent application
also note [0025] hydrogen
ELECTRIC GENERATOR - Google Patents
It is not coincidence that negative resistance zones along with solid state junctions have been utilized in OU devices.Last edited by mikrovolt; 07-09-2011, 08:48 PM.
I have a question thats been bugging me. Are these cells galvanic even though they use a solid dielectric instead of water? Like the Cement, glue, and gel cells could they be galvanic? The electrolyte they're in is a solid so how would it break down especially in the cement and glue cell, they are held together so no break down can occur.
Once the cells dry I don't see any further deterioration of the plates. I even short them out for long periods of time (weeks) and they still seem to find there way back to original voltage, sometimes even go higher. The Amps are the same way too.
I have one glue cell that doesn't act like a normal galvanic cell. this cell tends to fluxuates. The fluctuation are not directly proportional to the temperature or humidity. The cell could look like its draining in the morning but when I come home the voltage sometimes goes up. This cell has been hooked up to a load for a week now and has not "drain". The cell fluxuates between 300mV to 600mV. The voltage is never the same everyday but its never been 0 volts either. Just when you think its going to drain like chemical battery or capacitor it for some odd reason starts charging again, likes in a predetermine pattern. You short this cell out and it returns back to its original voltage and amperage. I also noticed that right before the full moon the cell started draining, but after the moon was full it started to charge up again.
I really don't think a galvanic cell would fluxuates at all, it seems to me that a galvanic cell would be a linear downward curve to zero volts. What do you guys think?All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
Ah, that's a different circuit. I guess a question I should have asked is what circuit is Aaron using in the video I posted?
I put some rods in the ground and tested it, and then I built the circuit from the first post later that night anyway and it worked, but I only had 5uH inductors so I bought what I need yesterday, haven't tried it yet. With the 5uH inductors the LED was pretty much the same brightness as without the circuit, just using a small capacitor across the rods. Then again I hadn't removed the resistor from the original solar light circuit and the capacitor I connected to test earlier was still connected, so I have more to try soon.
@ Ib and All:
I don't know if these cement cells using beach sand are galvanic or not, but they are working to produce free led lights.
The pictures below are of the cells that were made just yesterday, using as much copper wound into a spiral and inverted through itself as I could fit inside of the cans. Some baking powder was also added
The last picture is of a cell made using a capacitor can. All these cells have between 55 and 70 mA., and about 1.2 volts, or so. I have gotten 7 volts by combining several cans, so far.
I've made a video which shows the leds lighting up without the flash affecting the picture. But I haven't uploaded it yet. In any case the leds are fairly bright, and are connected direct to the three aluminum cells in the picture. The single capacitor can does have a small Jt connected on it.
My goal is to have them produce at least 12 volts... and some amps too.
I'm getting there...Last edited by NickZ; 07-23-2011, 03:43 PM.
Matt:
Yes, thicker aluminum is on my list. Possibly the square aluminum window siding that is 1"by 2" may work well, as it is about 1/8" thick. Or the aluminum tubing that is at least an inch thick. Mass seams to be important here, as more mass, means more output... My newest cells can maintain a steady 50 mA each, under a load, right now I've got 16 leds connected to three large cans, plus the capacitor can also.
Using thicker copper, and the inverted winding also helps.
The capacitor can is at least four times the thickness of the beer cans, but does not really seam to work any better. It is about 60% of the size as the other cans, and it can almost keep up with the bigger ones as far as current output. Same voltage 1.2 volts, and 55 mA, compared to 70 mA in the tall aluminum cans.
