Junkyard electricity
  • #46
    What!?!?
    I thought you all might sit and laugh at this drawing.
    • #47
      Off topic
      Okay, a little off topic but a cheap spark gap can be had by drilling a hole in the side of a pencil.
      • #48
        no spark gap?
        Are you talking to me? I am not questioning the possibilities here.
        Can you show a circuit or a direction to go in? Is this a Don Smith?
        What does the spark gap do to help this? If any. No spark gap?
        HV can be fun.
        ok bromikey, I will try using the pencil spark gap in the charge battery circuit after finishing this build.
        I will also draw an update of my build.
        Until then check out this possibility.
        Will it work?
        • #49
          Nonpaper schematic
          Here is the current hookup from the top.
          It runs at the same speed until about 4 volts then shuts down.
          • #50
            • #51
              • #52
                More of my broke build in photos.
                The man, Stonewater on the forum, has witnessed my vids I shared with him.
                Maybe he still has them?
                Nevertheless, he did witness by proxy, my work.
                • #53
                  Stator
                  Here is the set up for the sg circuit and the other coils.
                  • #54
                    The latest reading of voltage use since the last photo.
                    The caps seem to be doing their job in reducing battery consumption.
                    • #55
                      I am trying to accurately put on paper what is built out of junk.
                      If anyone finds a mistake, please do say something.
                      Thank you.
                      • #56
                        • #57
                          Greetings, I am digging your work. It helps inspire me. Keep it going.
                          I have been tinkering with an idea to use 2 bedini style pulse energizers to spin a Whimhurst generator. I am building a small one first as a proof of concept, I just got another batch of transistors so I can fix my current experimenters wheel.
                          Peace within
                          Treven Gee
                          • #58
                            • #59
                              Coils Are Shaped in thought
                              Maybe a drawing of an idea could help me to understand a concern over square cores.
                              Triangles make up squares 2:1...
                              • #60
                                Cap dump circuit
                                Hey BroMikey, the cap dump circuit is a simple one, right from your website.
                                I only have an electret photo flash capacitor @330wv @120 microfarads and a
                                200 vdc @ 270 microfarads.
                                The photo flash would not work, maybe not the best choice, but I only have those two choices, remember this is what I find in my garage.
                                I hooked up the 200 vdc 270 microfarad capacitor and it flashed then glowed on the charge circuit side and stopped flashing.
                                What is your mind set on this tiny problem?
                                Thank you.
