Question
I hope this doesn't seem to dumb a question. What if you used something like a 555 timer chip on the bedini circuit to pulse the coil and then collect the radiant energy as you do now, Couldn't you loose the wheel all together then? I am still learning about these things so I hope that question doesn't offend anyone.
George Mielcarek
George Mielcarek
Now I can use all the wheels and bearings I was going to use for a Bedini wheel and use it to tinker on my attraction motor.
. Now I see that the neon is unable to protect these transistors even though these are able to operate around 200 volts, but when using a 24 volt system you have no hope but burn them all. So I certainly recommend the Zener protection for everyone, unless you want to spend $ for transistors!!
I have decided to switch all of them to MJ15022 as they work wonderfully.
btu 81 % is not bad i wonder if the sg give that back if it were under load ?
