Testing cores...
Results from testing cores
-- Empty core
Rotation 790 RPM
Output voltage to to charging battery: 1.30 V
-- Solid Iron rod
Rotation 1123 RPM
Output voltage to to charging battery: 2.3 V
-- Iron filings mixed with glue
Rotation 825 RPM
Output voltage to to charging battery: 1.25 V
-- Welding Rods
Rotation 1139 RPM
Output voltage to to charging battery: 2.97 V
YouTube - Testing Bedini SSG with different core material 12
YouTube - Final look at the core testing with the Bendini SSG 14
YouTube - More looking at the SSG Core testing various types 13
-- Empty core
Rotation 790 RPM
-- Solid Iron rod
Rotation 1123 RPM
Rotation 825 RPM
-- Welding Rods
Rotation 1139 RPM
.. i clicked on all of them but could not find what i was looking for. Any chance of a direct link?
) so i wonder if this is this is what rapidly turns off the transistor and causing the current to pulse rapidly instead of gently like a sine wave and allowing multiple pulses per magnet.
I don't get it. It runs great for hours with no heat in the circuit but then as soon as i swap the batteries for the first time (always disconnecting the primary battery first) it stops working! After investigation i find all three of the transistors are dead! The neons are hooked up and i have never had any problems like this before. It only began happening once I started using a higher guage wire to connect the batteries and balanced the circuit though i don't see why that would do cause it to fry from being turned off.
Consider moving up to the mjl21194 transistors as well, or though you'll be crying harder if you fry them at 5-10 bucks a pop. If your local store doesnt have any more 2n3055s there are other similar subistutes.
