If...
Only if air was shaped like a tube. That you have made is a climber nothing else. Just like a person who can scale a 3 foot space inbetween two walls. You can tell the same principle is going on here because your tube did a twist as it was running. Lidmotors would have flown off the table if it had any real propulsion effect. Of course lid isn't driving with much voltage or current either so there is a possibility but a slim one at that. Good job guys.
But I do like the innovative way you guys are experimenting. Using two magnets would give the field an oblong shape facilitating a paddle type of rotor and a stronger force to generate from.
. I moved all this 'stuff' into an area I can play lab in
. With my set-up the balance between the 'load' and free running is somewhat critical. When the load is 'just right', the magnet will actually seek out the sweet spot and stay there. I have tried several additional rotors (satellites) and they act more like a disturbance. I get different beat frequencies in the load (LED's pulseing) and vibration of the main rotor, not harmony. Anyway, I posted a new vid today because I had reached a goal of 100 volts with a load.
