Originally posted by Bit's-n-Bytes
I see this still differently than you do. I have not put a scope on it, because I think the probes are fried, although, I may try it again today.
Q9 in your situation is exactly like a diode except that you can turn it off. So you are running a modified 2 transistor design for the most part. I see Q9 not as pressure release valve, but a pressure increasing valve. When you open the valve, more charge goes to batteries 2 and 4 and NONE goes back to battery 3. So you are closing off this path by opening the transistor. Now, you really have no time delay between firing Q1 and Q2. You could code it that way, but it was not there in the code you posted the last time I saw code from you.
I thought JB said we could run this from 10% to 50% duty cycle? He did not say 100%. You would need 1/2 dead time on each side to run at 50%. Hopefully you are still gaining charge, I will go check mine out this morning. He did however mention a path for current in the top and in the bottom, but we are actually creating AC on the two bottom legs in which AC was not meant to be created. AC was meant to be created in the battery 3 to battery 4 negatives. JB said that no charging took place on the AC side.
So, I can definitely duplicate what you have done, which is GREAT. I'm just not sure this is exactly where we want to be, but it is a repeatable experiment and everyone can do it if they have a digital means for control.
[***EDIT my batteries lost potential, but I coded it significantly different than Bits, so this has nothing to do with what Bits is doing. I did not believe that Bits was doing coding it correctly, but he may have been, because my batteries are significantly lower this morning than last night...about 7 hours run time. I was using delays between switching Q1 and Q2 and less off time for Q9, so I still need some fine tuning on the coding, the hardware seems to be fine. Should have just done what Bits did and see if batteries gained charge! ***]
Leroy
hope you don't mind.
