mega coil (help 2)
It sounds like the resistance of your coil is too high for a simple continuity test. I am not familiar with a meter that shows a 1 only when resistance is out of range. You might try selecting a higher resistance scale on your meter until you can actually read the resistance of the coil. The nine volt battery test shows that you actually have a connection through the coil, but it may be of very high resistance. A digital meter will read the voltage through the coil even if the current is only a few microamps. If the resistance is very high there was probably current going through the bulb when you did the bulb test, it was just too low to light the bulb.
Good luck, citfta
Good luck, citfta
Great minds... lol
Next best is to look on youtube for videos on electronics, I have found many how to videos there that have helped me along the way when i had questions of what to do. I have found that digital multimeters are not fast enough to give accurate readings. Old analog meters do a much better job.
